New Server Migration
Hello everyone, Pandemic here. I wanted to let everyone know that we're working on migrating to a new server which will allow for more update flexibility including SSL certifications. The old box is really old and it's been time to find a new one for a while.
Data was migrated to a the new box a few weeks ago. We're working on testing the page to ensure it actually works before we go live. If anyone has any web development or coding experience and wants to help, DM me.
Thanks!
Difference between Driver & Passenger Axles Manual Trans
    Sorry I did not have time to fully search but, is there a difference between the Driver & Passenger side axles?
    My Raxles boots are destroyed on the driver side & the passenger side is clicking like crazy so I bought a set off of 1A Auto lol. <- Probably garbage
    The set I ordered, both axles look identical & each box does not have a separate part number on them so it is confusing.
    I read that even the auto & manual passenger side axles are the same but, are the passenger & driver manual trans both the same?
    I cannot tell which side is which.
    Keep Pushing..
    All of the sites indicate that the Front Left (driver’s side) is 3mm shorter when compressed than the Front Right (passenger side) axle. Auto cars lack an intermediate shaft and have unequal axle lengths.
      They are different. The spline depth is different so they are NOT interchangeable.
      1991 Accord Lemons Race Car, "The Minnow" RIP
      1993 Accord Lemons Race Car, "SpaceEx Starship"
      Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
      Adj Upper Control Arms -3.0deg front, -2.0 deg rear
      M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
      Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
        Oh god! This is extremely accurate! I completely blanked that Rockauto kept sending me passenger axles when I needed and ordered driver’s side axles and they didn’t fit. Thank you for correcting my egregious misinformation.
          Originally posted by SSMAccord View Post
          Oh god! This is extremely accurate! I completely blanked that Rockauto kept sending me passenger axles when I needed and ordered driver's side axles and they didn't fit. Thank you for correcting my egregious misinformation.
          I learned this myself, at a race, on my back, covered in grease, while holding the wrong axle in place while someone was hammering on the end trying to get it to "pop in." Eventually we figured it out. Now we never go to a race without one backup axle for each side.
            Soooo late to the party here. Sorry guys! I slack when coming on here to check back. I did get it all sorted out, I just double checked part #'s & was good to go!
            Thanks as always for the replies!
            Keep Pushing..
