My car for about the last year has been making a terrible vibration while accelerating in 2nd gear (manual), most prominent under light throttle conditions. I posted this up a few weeks ago and got no real answers. All I know is this does not happen in any other gear as far as I can tell. However, this vibration started to become noticeable after I had my driver's side CV joint replaced. When I asked the mechanic, he dismissed it as a transmission problem. I still think it might be a defective CV joint. Is this a possibility as it only happens in 2nd gear...and happens much more when it is cool and humid out. The vibration is just annoying and embarrassing to me at this point. The alignment is fine, the car pulls fine in other gears. I know the ball joints and struts are good as well. Is there anything non-transmission related that would cause this. The car shifts fine. If worst case scenario it is the transmission would changing the oil in it help the situation. thanks
Vibration in 2nd
That same thing was happening to me although I have an automatic it would happen from 30 to 40mph. I took it into the shop and they thought it was the transmission too. I assured them it wasn't and they put in new axles. After about putting in 4 different axles we finally found a good pair. Apparently they said they have alot of problems with the 4th gen axles they get from napa.
