ENG: Setting the TPS Sensor
    if my car stumbles right when it first starts up but then goes to normal the rest of the time, is my TPS not calibrated correctly? I've got the H23 TB/Plenum swapped onto my F22A6 and I reused my A6 TPS by notching the rivets to reuse the screws. I don't have any CEL's or anything. But is the TPS to blame for this misfiring at first start up? it happens pretty much everytime I start my car, cold or hot.
    member's ride thread
    91 Accord SE 176k
      mine stubles and i calibrated mine...it aint that hard, just get a t-tap and use the battery as your ground.
      I <3 G60.
        so a t-tap? is that thing you got pictured above?
        91 Accord SE 176k
          whats the deal here i have to do this soon cause my tps was broke on my swap.... should i buy a new one or just use the tps that was on my A6 tb? you have both the yellow and red wire in that t-tap?
          Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
          Originally posted by deevergote.
          But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
            I have that fluxuating idle now as well with no CEL code. And the voltage is at .49Volts and thats the lowest it can go. Whats the problem?
            My CB For Sale
              I <3 G60.
                been there done that, next.
                My CB For Sale
                  that link wasnt for you dum dum.
                  I <3 G60.
                    I'm gonna check this tomorrow since I just got a multimeter, my stumbling hopefully is caused by a bad Ignition Coil. I measured the resistance and pins B-D don't have a reading which indicates that something's up w/ those pins, specifically pin B doesn't since I checked all 4 individually, sorry for going
                    So a T-Tap is just a way of latching onto the wire w/o damaging it? my multimeter just comes w/ the two black and red wired probes would that be okay to check the TPS with?
                    91 Accord SE 176k
                      oh and thanks for the updated link, the OP one didn't work but this one does now.
                      91 Accord SE 176k
                        got to try this cuz my car idles too high!
                        93 Accord LX Sedan (sold)
                          okay i'm trying to do this....but its not working. I have the positive lead on the red wire and the negative lead I have on the engine block. Its giving me no reading at all.....? anyone?
                          91 Accord SE 176k
                            i am using a t-tap...means you're not making penetration./
                            I <3 G60.
                              I cut it down to a bare wire and am touching that w/ the red lead....and the black neg. lead i'm just touching on the engine block. And still no dice....
                              I am using my friends P13 Manual in my Auto though b/c my Auto P13 took a crap on me....could that affect the TPS sensor reading at all?
                              91 Accord SE 176k
                                and you make sure you have the key to II...
                                the only other possible thing would be if the ecu wasnt sending power to the sensor. i would check that at the plug.
                                I <3 G60.
