Hello Everyone! It is HIGHLY recommended if you have a 90-93 TCU that you replace all the capacitors listed in this guide as preventative maintenance, otherwise you may have to get creative in your repair (if even repairable), and the area of the board that gets damaged could be different from this case. I only paid $5 from a local electronics supplier for all the parts replaced in this guide, as I already had access to the tools.
Description:
A very common problem alot of 90-93 accord owners suffer is their tcu computer going bad, which restricts the driver to 2nd and 4th gear; the sport light comes on, and when you try and pull a code you either get 0 or no codes (My case), or 6+ different codes at once. In my case, either a Capacitor leaked, or shorted, which caused 2 resistors to flare, burning out, which resulted in some damage to the board.
Tools:
Soldering Iron
Solder
Desoldering Braid or Solder Vacuum
Wire cutters
Hot Glue (Not required for preventative maintence)
Parts List: (Less than $5 from a local electronic component supplier)
Capacitors:
1uf 50V
330uf 10V
33uf 35V
220uf 35V
4.7uf 50V
Resistors: (Not required for preventative maintence)
2x 15 Ohm 1/2 Watt
I replaced all the capacitors on the board, and since the original mounting holes for the resistors were covered in carbon, I had to be a little creative in the repair job. The two resistors are suspended in Hot Glue, which act as a vibration dampener, while holding them in place, plus it can easily be peeled off later if needed.
Here are some pictures of my fried TCU:
Here are pictures of my TCU after being repaired:
Description:
Tools:
Soldering Iron
Solder
Wire cutters
Capacitors:
1uf 50V
330uf 10V
33uf 35V
220uf 35V
4.7uf 50V
2x 15 Ohm 1/2 Watt
