A quick diy on removing the whole headlight bracket with corner lights and removing the bumper. I noticed most of the bumper diys have no pictures, so i just threw those pics in too.
TOOLS REQUIRED:
12mm wrench/socket
10mm socket/wrench
phillips screwdriver
at least two braincells to rub together
STEPS:
Disconect negative battery cable
BUMPER REMOVAL:
Open hood and remove grill.
Remove the screw on each bumper light and remove bumper lights circled in red.
Remove the two 12mm bolts on each bumper mount circled in red.
Remove the 12mm nut behind the headlights circled in red.
Remove the two screws on both ends of the bumper circled in red.
Pull the edge out a bit to get it over the lip of the little clip that the screws go into.
Pull off the bumper.
HEADLIGHT REMOVAL
Remove the 3 10mm bolts circled in red.
Be prepared to support the headlight and bracket. DO NOT let the headlight hang by the wires for the bulbs.
Remove the 2 10mm bolts circled in blue.
Repeat process for other side.
Hold the headlight in one hand and use the other to disconnect the plugs. (the high beam connector might be a little harder to reach so you ca just pull the whole bulb out if needed.)
The plugs that need to be unplugged. there are two for the corner light hidden, but the arrow is pointing at them.
the corner light connectors and bulbs.
The low beam connector.
The high beam connector and bulb.
Installation is exactly reverse of removal.
Finished product.
TOOLS REQUIRED:
12mm wrench/socket
10mm socket/wrench
STEPS:
BUMPER REMOVAL:
HEADLIGHT REMOVAL
Finished product.
