choppacity : 1992 Accord LX
Last edited by choppacity; 08-23-2013, 01:37 PM.Originally posted by QuashishHoly crap thats a clean F series. jellish mang.
Quashish dictionary
Jellish: (adjective) Jel-%i'sh+#
To envy something to point of almost blowing a load involuntarily.
Originally posted by choppacity View Post
Whats up guys, Ive been working hard on the car fabricating alot of stuff that i need! for example, my own version of esp's alternator relocation! cost to me about $14 just for the materia and a couple evenings!
Just finished welding my downpipe with recirculated wastegate! im gonna go over the weld a little hotter this time so i can strengthen it. i was originlly scared of blowing through the pipe. This was my first time attempting anything of this nature and i couldnt be happier with the outcome!
I also swapped the manifold from a log to a topmount i bought off CL, guy had it on his H23 prelude. I cut off the t3/t4 flange and welded my Vband flange on there!
Quashish dictionary
Nice work!
Such a shiny motor... drool.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Quashish dictionary
C-3PO's MRT USDM yo!
Thanks for the compliments guys! Im doing what i can but my lack of automotive knowledge is holding me back. I just dont want to end up with a F series paperweight haha
Originally posted by Quashish View PostHoly crap thats a clean F series. jellish mang.
Quashish dictionary
Quashish dictionary
Love the blk engine and head. I painted mines black also. But yours looks nicer.**Blk Housed Slut Crew Member #1**
whats crackin guys,
decided i would update my build for you guys!
trying to finish it up in between two jobs and school but not too far away!
Heres a shot of the engine bay as of right now. Because of the way i decided to run the IC, pie cutting straight aluminum tubing and then welding it was the only way i could do it. i pressure tested everything to 40psi with my boost leak tester
Finished one of my headlights, found out the passengers side is cracked so i need to source another one before i seal them with butyl. Retrofitted with Morimoto Bi-xenon H1 projectors. 5k lowbeam 3.5k highbeam
Just received all my brake calipers too! Acura legend 2pot along with ROH cl hubs up front. Just need some rotors and pads! Oem rear disc calipers converted from drums with a 40\40 prop valve.
Couple questions i have for the community,
For then rear brakes i bought a techna-fit braided line kit. Then last portion will not reach to the caliper without bending the sh!tout of it! That's also with with the angled neck on the banjo fitting facing the wrong way.Am i doing something wrong? here's a picture for reference
For the front rotors, could i still use the 94 Prelude VTIR 282mm rotors with the legend calipers utilizing the 28t bracket?
Thanks for your help and support guys!Originally posted by QuashishHoly crap thats a clean F series. jellish mang.
Quashish dictionary
Originally posted by choppacity View PostLMFAO! Thanks, Quashish! I might have to put that quote in my signature! haha
still looking good!
Think its time to update! Got the whole brake line issue solved, after speaking to techna-fit! the sent me new line that were a slightly longer and its all good meow! Set the ride height over the weekend but now im thinking of running new larger diameter fuel lines along with an external fuel pump for convenience. Heres how she sits!
Quashish dictionary
Originally posted by choppacity View PostThink its time to update! Got the whole brake line issue solved, after speaking to techna-fit! the sent me new line that were a slightly longer and its all good meow! Set the ride height over the weekend but now im thinking of running new larger diameter fuel lines along with an external fuel pump for convenience. Heres how she sits!
