BUILD PICS PAGE 4 and 5
My 92 LX
Bought her with a salvaged title for 400$
November 08' Got it straightened out, took out all the dents out and painted her FROST white
92 LX
ENGINE "New Setup"
F22A1 Block-F22B DOHC
Bore x Stroke: 86mm x 95mm
Displacement: 2207cc
Valve Configuration: DOHC 16 valves
Compression ratio: 9.1
Max power: 643whp
Rev Cut: 8200rpm
-BISIMOTO 2.4 Turbo Cams
-BISIMOTO F22B/F20A Valve Train
-BISIMOTO Arias 86mm 9:1 Forged Pistons
-BISIMOTO Long Ratio Rods
-BISIMOTO 86mm Headgasket
-BISIMOTO Cam Gears
-OEM H23 valves
-OEM H23 valve stem seals
-OEM Bearings
-OEM main bolts
-OEM GSR Timing Belt
-OEM F22a WaterPump
-OEM F22a OilPump
-Precision 6262 Turbo T3/t4 .82 A/R
-Injector Dynamics 1000cc fuel injectors
-Aeromotive 340LPH fuel pump
-Koyorad R-series radiator
-ARP rod bolts
-Hondata intake manifold gasket
-KS Balance Shaft Eliminator Kit
-KS custom turbo manifold
-KS 2 1/2" to 3" downpipe+dump
-M2J5 Tranny Synchrotech LSD
-Competition Stage 4 Clutch
-7lbs Findanza Flywheel
-ESP Mounts
-ESP slim alternator bracket
-Garrett t3/t4 60 trim 82 A/R
-Greddy RS BOV
-Tial 38mm WG
-Hondata 4 bar map sensor
-Precision 780cc injectors
-Gutted Intake Manifold + Runners
-ARP Headstuds
-3" Mandrel Custom Exhaust
-Badlandz Electronic CutOut
-Cusco Catch Can
-AEM dryflow filter
-AC Delete
-PS Delete
-Chipped p28
-eCtune software
-Tuned @ KiazenSpeed by Ried (310whp, 294wtq@13.5psi on 2.5" exhaust)
-Tuned @ KiazenSpeed by Ried (505whp, 486wtq@20.5psi)
-Tuned @ KaizenSpeed by Ried (534whp, 448wtq@21 psi with new turbo)
-Tuned @ KaizenSpeed by Ried (643whp, 529wtq@30psi with new turbo)
EXTERIOR
-Fresh Frost white paint job December 08'
-Full body work
-94 legend coupe lip
-USDM Black Housed Headlights
-JDM CB3 Side Markers
-AVS Window Visors
-OEM Mud Guards
-Sedan Trunk & Light Conversion
-5% Window Tint
-J Square Grill
INTERIOR
-Stock!
-Type R replica steering wheel
-NRG quick release
-Garrett 30psi boost gauge
-In cab manual boost controller
SUSPENSION/WHEELS
-Rota RB 16x7 + 22
-Dunlop StarSpecs 205/50
-BlackWorks SS Full coil overs
-TAS BIG Brake Kit V6 wagon
AUDIO/ELECTRONICS
-Oldschool Panasonic Deck
-Unknown Brand 6x9
FUTURE PLANS
-Full suspension restoration
-Stereo sound system
-Traction control bars
-Strut Bars
-Forged Internals
-Raise the BOOST
My other coupe
Old video of last year, still had the 2.5" exhaust with recirculating WG dumb. NON LSD sucked!
, in the mean time I doubled stacked the Custom IAB plates, installed a 72mm BLOX TB, Im also changing my catch can setup to a proper more fitted one, Still in Progress.... Got two A/N fittings welded with two stainless steel braided hoses. Also took the time to repaint the vavle cover two tone; wrinckle black with some polish. cant wait to retune it at 14psi soon.
