F20A CB7 : 1990 Accord LX
the center is from a 94 to 95 honda well the outer is the cut out of a 90 to 93 . made by you.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Close. The outter is 9293 and inner is 9293 i used a dremel.
From the front grill**Blk Housed Slut Crew Member #1**
Collector mod for the exhaust coming soon I will post pictures of all the correct parts what I get them in..**Blk Housed Slut Crew Member #1**
looks like it is come in along good . have you had any more problems with the theifs ?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by deevergote View PostMost autoparts stores should carry Duplicolor touch up paint to match. It won't likely match very well now, though... 25 years of sun-bleaching makes the car's paint quite a bit lighter.
Originally posted by DCB7 View PostYeah that's true. It was a type of grey spray paint I saw though. Someone used it for headlight eyelids. It wasn't that far off.
http://www.automotivetouchup.com/spr...t_matched.aspx
Thanks all.**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View PostThanks all.
Originally posted by Theos92VR4 View PostIve used this site many times (for stuff like lips, mirrors, etc) It has always been a perfect match. I even did a full bumper and it came out excellent
Thanks tuner. Im proud to own a cb.**Blk Housed Slut Crew Member #1**
