Siik whip homie
Slick_Nine : 1993 Accord LX
hey slick! I found out how to install the rear mudflaps! for the passenger side, you're gonna have to do some cutting because the wheel well is too shallow (when you fit it you'll know). I used a box cutter to cut a chunk off, and then I had to redrill a couple new holes for screws. where it screws into the wheelwell wall (behind the wheel) you'll need to relocate the hole a little lower and off to the side a bit. for the bumper area, you're gonna align the mudflap so that you can use at least one of the original mudflap screwholes. I aligned the top mudflap hole with an existing hole on the bumper, then drilled a new hole for a screw into the bumper and mudflap.
^sounds confusing, I know. but when you take off your rear bumper and try test fitting a rear mudflap, you'll understand what I said up there and will be able to manage! you did it with my cryptic side skirt instructions, i'm sure you can do it with this too
Originally posted by Justin123560 View PostSaw you going up hayvenhurst towards Plummer. I gave you a friendly wave haha.
Originally posted by WI_Zoe View PostSiik whip homie
Originally posted by P5ylance View Posthey slick! I found out how to install the rear mudflaps! for the passenger side, you're gonna have to do some cutting because the wheel well is too shallow (when you fit it you'll know). I used a box cutter to cut a chunk off, and then I had to redrill a couple new holes for screws. where it screws into the wheelwell wall (behind the wheel) you'll need to relocate the hole a little lower and off to the side a bit. for the bumper area, you're gonna align the mudflap so that you can use at least one of the original mudflap screwholes. I aligned the top mudflap hole with an existing hole on the bumper, then drilled a new hole for a screw into the bumper and mudflap.
for sure, when i get a chance i'll take some pictures of the rear mudflaps in better lighting so you can get an idea at the moment, my car is being garaged because my automagic died. gonna replace it with another one :3 but in the meantime i've been installing things that have been sitting around.
Originally posted by Justin123560 View PostDid you go to that meet in porter ranch cause I think I saw your car in a video
Link to said video?
Dude your car is stunning! I skimmed threw real quick but didn't see the answer I was looking for, so I guess I'll just as you lol.. What type of rear lip is that and what type of exaughst is that? And I own a sedan so not totally familiar with the coupe but are those the original side skirts for the car too? Thanx in advance and keep up the good work!!
Originally posted by TEXAS_CB7_25 View PostDude your car is stunning! I skimmed threw real quick but didn't see the answer I was looking for, so I guess I'll just as you lol.. What type of rear lip is that and what type of exaughst is that? And I own a sedan so not totally familiar with the coupe but are those the original side skirts for the car too? Thanx in advance and keep up the good work!!
Originally posted by P5ylance View Postif i have time... and motivation... I may try the CD5 rear lip again, but this time a different and hopefully better way (to deal with the gap issue)... but it would do away with the rear mudflaps and I kinda like the sporty look of it... bah! decisions!
The Caravan 2015
yeah, I noticed he had these side flaps that went over the rear lip and reached the end of the bumper... I wondered what those were. I remember seeing that picture and wanting to do something similar, I was actually considering making something similar to the G35's rear mud spats to kinda flow into the rear lip... then got lazy and just worked out the CD mud flaps hah
