Originally posted by JunyAccord
View Post
Ol blue : 1993 Accord EX
Update:
First off I have gotten the best gas mileage to date with my mp1a trans at 27.2mpg. I ordered a 11.5lb flywheel, 8 flywheel bolts, and the SS clutch line from valexracing. I will be ordering a exedy clutch kit, clutch slave and master cylinder to this weekend. I have the axles and clutch pedal assembly already. The only thing I will need now is the rear manual t-bracket for a manual car.
The head for my built motor is being put together tonight and I hope to god I get to get my block done soon. So when winter comes around the engine and trans should be in the car. Than next spring it will get lowered and rims. After all that my 1984 z51 vette is going to get all my love and attention with a 5.3 lm7 ls swap with the stock 700r4 trans.
We will have to meet up some time, I like the wagons. I'm the Bill that Jarrett is talking about, and I have a MP1A LSD for my SE turbo build. What TCU did you use? I dig the shop you got to keep the CB7 in, reminds me of the one in Texas with all of my tools in it.
Jarrett, someone would have to pry that transmission from my cold dead hands!1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostWe will have to meet up some time, I like the wagons. I'm the Bill that Jarrett is talking about, and I have a MP1A LSD for my SE turbo build. What TCU did you use? I dig the shop you got to keep the CB7 in, reminds me of the one in Texas with all of my tools in it.
I will be needing an ECU this winter, like a P06 or P28 or something I can chip.
Do you have the part number for your TCU?1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by Alex13mod View PostGood trade and good start, I love your detail work I need to practice on doing that on my own.
Originally posted by wildBill83 View PostI will be needing an ECU this winter, like a P06 or P28 or something I can chip.
I have a P06 that you could chip, I bought one off sonikaccord so I don't need it anymore.
All of my parts came in this week.
Exedy pro kit clutch
Fx chromoly flywheel 11.5lbs
Sachs master and slave
8 flywheel bolts
Clutch line from valex
I also grabbed all my parts from my buddies house.
M2s4 trans
Pedals
Shifting cables
Shifter plate knob and boot
Tbracket I didn't know I had
Axles
Starter
H22 plenum and throttle body
Nice progress.
You may have to grind some of the bolt off on the valex line to get it to seat. I did on mine. The bolt was too long I just took my grinder to it. No problems with leaks or anything going on a year or so.
And back in the day I had trouble with Bosch 02 sensors in my car. Don't know why and maybe it was just me.
What kind or wax or sealant did you use after the polishing. I have the same setup and use the 105 and 205 as well. I recently bought some chemical guys carnuaba and I think it looks great. Two coats. And I bought some of chemical guys liquid carnuaba spray stuff for in between waxes.
Keep up the good work.
steve
How far from me are you? If you aren't too far we should get together some time. If you need a hand with anything let me know.
Got tired of the MP1A already? Pm me a price for your P06 and MP1A TCU.1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by wildBill83 View PostHow far from me are you? If you aren't too far we should get together some time. If you need a hand with anything let me know.
steve
I hope the rust prevention works for you, But no worries the sedan rear quarter panel from the sedan are the same as the quarter panels from a wagon.
I used sedan repair panels on my wagon, i also did the rust prevention while i had the bumper off.CB7TUNER.com
Originally posted by cb9love View PostI hope the rust prevention works for you, But no worries the sedan rear quarter panel from the sedan are the same as the quarter panels from a wagon.
