https://www.thedrive.com/news/33572/...denly-collapse
According to Harbor Freight, the recall applies to three-ton and six-ton heavy-duty steel jack stands with item numbers 56371, 61196, and 61197. The number on the three-ton units can be found on the label at the top while the six-ton stands have their numbers printed in the yellow section of the label found on the base.
Based on the NHTSA filing, the recall applies to a total of 454,000 jack stands made between 2013 and 2019 and the issue is apparently blamed on old tooling used by the factory. Naturally, affected stands that have yet to be sold have already been removed from Harbor Freight's inventory.
