To safely rev a DD F22a to 14-19k on a daily basis?
What would it take....
MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfuckerTags: None
More money and knowledge then you will ever obtain.Originally posted by GeoffMisiak View PostTo safely rev a DD F22a to 14-19k on a daily basis?
The Official CB7tuner bookstore!!!!!!!!!!!Originally posted by Ralphie View PostMore money and knowledge then you will ever obtain.MRT
What'll that leave me with?Originally posted by LoDollar92LX View Poststart by de stroking it by 50mmMRT
A shorter crank wont do anything, well depending on how much you shorten it.Originally posted by GeoffMisiaklol @Deity
So... forged pistons and a shorter crank?
I suppose if you wanted you could shorten it enough and make it a single cylinder engine.
Destroke does not mean a shorter crank.
In order to run in the vicinity of 14k rpms, you need to lower the rotational mass, and have a short stroke to obtain lower piston speeds.
Ultimately It would no longer be a 2.2 liter engine, more like 750cc.
And then you would need to look into a custom built cambelt in order to compensate for the lower block height.
Look up F1 engine design and construction, that will give you SOME insight into what is required and why it's required
My 5.7 LS1 Holden Ute
Reciprocating valve bodies. Valve springs will float at that RPM. Like said earlier... LOTS of money!Originally posted by Junior SmurffNevermind guys, google search works wonders!
Safely for a DD? Not gonna happen. Probably wouldn't happen ever.
It would be cheaper to get an engine from an F1 car and swap it in. Those have a short stroke, and small pistons. For something spinning that fast, you don't want a lot of mass at the end of the rods.
Of course, since there are some serious secrets hidden in those engines, you'd probably have to kill someone to get your hands on one.
Hey! It's an honest question.Originally posted by deevergote View PostNo, he's just a troll that likes the attention.MRT
F22 = not gonna happen
A much more realistic way to rev to ~16,500rpm in your Accord is a Yamaha R6 motor swap. A bike motor in a car has been done so you could try contacting someone who has done it and figure out what all you need.
You could probably do it for under 15Gs including parts and labor if you find a good fabricator who would be willing to do some fab work on the side.
It would be pretty insane and pointless though because you can just buy a motorcycle?
Follow the math:Originally posted by rob_is_legend View PostWhy is he still here? To be honest, I've been limiting my participation on the forum because guys like this do nothing but cause a headache.
I > U
A hayabusa is in my future, but I still would like to build a decent motor that would rev to 19k. Swapping in a bike motor wouldn't help, just like swapping in traction control wouldn't help.Originally posted by rexload View PostF22 = not gonna happen
It would be pretty insane and pointless though because you can just buy a motorcycle?MRT
