This thread is to address GeoffM and his beliefs (as well as anyone else's) that certain mental afflictions are purely imaginary vs. those that believe they are a mis-wiring or a chemical imbalance in the brain. I'd like to invite anyone with an opinion to voice it, but I'd like to keep this a civil, rational, discussion between intelligent people, no matter what they believe. I started it in order to have this discussion without threadjacking someone else's thread completely.
1: Okay.
2: I actually have very little stress that I can't manage by myself. I learned long ago that worrying and stressing only makes a situation worse. It's the surprise panic attacks for no reason at all that are my problem.
I fought this problem for a long time until I sought medical help. It was very hard for me to come to terms with the fact that there were factors inside my own brain that I couldn't manage.
Awake, yes, it's much more manageable, however it has caused me to have irrational thoughts that are anxiety related; my mind tends to blow things out of proportion, and I can step back, take a breath and keep it under control, but the thoughts are still there and pop up unexectedly. However, when I wake up in the middle of the night in the middle of a full blown panic attack, cold sweat, crazy pulse rate, almost hyperventilating, it's just a little unsettling and it does affect my life in a very negative way. Or in the middle of a beautiful afternoon, nothing bothering me, my life is peaceful and calm and out of nowhere I can feel the anxiety building for no reason other than the chemicals in my body are out of whack. I've used meditation for years, and have had sessions interrupted by a panic attack. These are not attacks I've thought myself into, they just happen.
3: Let's say as unarguable as possible, realistically speaking, beyond a shadow of a doubt in court, documented, etc.
4: No offense, but I gave you more intellectual credit for this. You should be more willing to keep an open mind and be willing to change. Just because you've decided that something is so doesn't make it so. When you're confronted with an overwhelming amount of evidence to the contrary, and very little evidence to your own belief, it might just mean that you're wrong.
5: That doesn't mean your brain didn't get rattled.
What common sense and logic do you have to use as a rebuttal against medical and scientific research and data collected, studied, applied and used successfully (and an unsuccessful attempt is still progress; now you know something that doesn't work)?
How do you differentiate between someone with ADD, ADHD, an anxiety disorder, etc. and someone with Autism? What criteria are you using to decide that the first group is just imagining it and the second group has something different going on inside their skulls?
As far as getting older, I see more and more how little I truly know and understand every day. I haven't lost sight of a damn thing.
Originally posted by GeoffM
View Post
1: Okay.
View Post
