Originally posted by reklipz
View Post
After really looking at the header the other issue is, you dont really have a whole lot of room to cut the downpipe after the collector to weld in a flange.
Look at the placement of the oxygen sensor bung. You would have to weld the flange below that, but then you are pretty much right on the bend that goes under the block. Plus the header hugs the block so tightly that you would never be able to fit the header and down pipe onto the car because the flange would most likely be directly up against the block.
