my friend and i are planning on building an f22 to handle some moderate boost. As all of you with aftermarket forged pistons know, they are pretty expensive. So i got an idea from d-series guys....just some ghetto things that they do
b16 rods, 75mm supra turbo pistons (boost)
b18a rods, any oem d-series piston (n/a)
suzuki vitara 75mm pistons, they have stronger ringlands (boost)
so i started looking for a budget 85mm piston, guess what oem turbo motor has them......
4g63......for those of you who don't know engine codes, that's the dsm (eclipse, talon, laser) turbo motor. Personally i think it would be ridiculous if those worked, f22a guys are already jocking dsms hard!
the bore is the same but of course you have the wrist pin location to worry about, those could certainly be machined to fit f22/h23 rods, but without knowing the height of the piston (distance from wrist pin to top of piston) it's hard to know what the compression ratio would be.
i'd like to try to get my hands on some oem 4g63 pistons, but all of my car friends are into the almighty H.
just some food for thought.
