possible cheap turbo piston!
    And the nail in the coffin...
    You guys are attemting to raise the deck around .100
    You ever put any thought into the fact that your going to need a custom set of head studs?
    Yeah, forged F22 pistons are going to be alot cheaper atthis point, cheaper and with out the ghettoness...
    Oh, and how about the timing belt... +.100 deck = stock timing belt no worky...
    Go ahead, write my name on the valve cover
      lol... is about all i can say....
      good shit... i love these debates..
      Praise The Lowered...
        yeah.. what about the timing belt... ever try to put a timing belt on something with a 0.060hg.. much less a damn 0.150 hg
          Let me guess rick..............
          you arent the proud owner of a cb7.
          Turbo f22a/f22b vtec
            no comment
              Its not a debate really... its a really bad idea, Im just pointing out why its a bad idea...
                thanks. from now on we'll try not to think of new ideas.
                  So let me get this straight:
                  $150 forthe pistons
                  $100 for the gasket
                  $20 x 4 to rebush the rods to accep the the smaller pin
                  $75-$250 for a H22 crank
                  Its a copper gasket so add the cost of O-ringing the block -$75-$100
                  All to ghetto rig a piston that was designed for use in another motor, another combustion chamber, another valve angle/depth...
                  Forged F22 pistons dont seem like a good idea after all that?
                  Forged pistons are like 500 bux, no one is arguing that these will be as good as a forged piston. They will not. We're just exploring the options on a cheap piston idea that won't break as easy as the OEM honda pieces.
                  also, the cost of the crank can't really be factored into the piston cost, because it's an improvement in and of itself, same goes for the rods. the 2G DSM pistons (8.5:1 in stock motor) have a 22mm pressed wrist pin, same as the honda, Shadetree had to have his machined because they were 1g pistons which have use a 21mm wrist pin
                  2g DSM pistons can be had for 100
                  Hussey HG 120
                  i didn't a copper HG require o-ringing, so then add 75-100,
                  IF the valve angle issue works out the advantage over forged pistons will be
                  -a cheaper price,
                  -and a better r/s (1.572 vs 1.489)
                  I'm thinking the valve angle issue won't be a problem with the amount of clearance we'll have, also b/c this is a dished piston
                  H.S.A.E.
                  90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
                  99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
                    Hussey HG 120
                    -a cheaper price,
                    Oh ok, so H22 cranks are free... I didnt know that, damn i wish I would have known about them eb8ing free before I bought 4 of them lat month...
                    Yeah, lets put a price tag on that since its required to make this not work...
                    H22 crank = $150
                    Gasket = $120
                    Custom length ARP head studs = $100
                    O-ring the block = $100
                    4g pistons = $100
                    new longer timing belt $40
                    $610
                    Forged F22 pistons can be found for $400-$500
                    So, you wantto pay more to ghetto rig some shit that wont even work, wasnt ment to work with your motor... for what?
                    lets give you the benefit of the doubt and say your .125 gasket only crushes .025, now you only have .002 deck clearance...
                    You ever though about the fact that the top ring may be close to or maybe even out of the deck at .098 out?
                    Bad idea x 400
                    Forged h22 pistons for less = good idea
                      the only good things about an h22 is its rod stroke ratio, and 2 cams. they also have higher compression.
                        Your missing a few lot of things
                          well out with it
                          secrets dont make friends
                            Vtec, oil squirters...to name a couple others.
                              Vtec? there's nothing good performance wise on vtec. Just fuel economy.
                                well out with it
                                A much much bette flowing cylinder head, 35mm intake valves, dual valve springs, primary and secondary lobes (great for gas mileage and all out performance), a better flowing IM, larger TB, higher compression, larger bore, longer rod, better crank (large, full counterwights, Ideal for performance), bearing clearances are more ideal for performance, higher volume oil pump, oil squirters to cool the factory cast pistons...
                                I could go on, but I think you get the point...
