basically the question is what is your interpretation of driving a stick shift the RIGHT WAY. What do you do when coming to a stop, turn corners, stop and go traffic driving, down shift, how do you shift in general, when parking, going uphill, going downhill, going up or down windy roads, parking up hill or down ect..
This is what I got from learning on my own:
I almost never downshift when comming to a stop, I just put it in neutral and coast on the brakes.
In case I need to pick up speed before I've slowed down completely I guesstimate what gear I need to go in to which usually works that or I just put it in to whatever gear it slides in to to continue moving.
In corners I usually slip it in to neutral as well and then put it in whatever gear I feel it should go in to it works most the time.
I've never driven on long winding roads or mountain roads. up or down hill.
Whatever little inclines I've driven on I drive as normal.
The hardest thing I've ever had to do was back up on a steep driveway... couldn't do it.
In stop and go traffic I alternate between neutral then shifting when there's long stops and holding the clutch down on first or second when it's quick stops or just cruising on first when it's just slow traffic.
I always use the clutch up shift, down shift, shift to neutral... whatever always use the clutch I've tried shifting without the clutch and it worked some times but other times it would grind and so I just stick to using the clutch to be safe.
When parking I just leave it in neutral with the hand brake on, it's pretty flat around here so I never really worry about it.
thats all I have. I would love to hear input from you guys.
*you could also add how you shift when racing on the track...
Brake pads are far easier to change than a clutch.
