cb7 automatic manual shifter with full line pressure
    I'm in the process of modifying and building a control box that will allow you to fully adjust and manually pick your gear you want to go to with up to full line pressure for the cb7 transmissions. Full line pressure means, example: my gsx through the computer shifts at around 90-125 psi with no valve ody work or shift kit, with this it shifts around 290-300 psi, without doing any internal valve body or shift kit work.
    What this would do, would allow for shift paddles to be intigrated along with a healthier transmission. Meaning with the flip of a switch you have full control over your transmissions gear selection and shift firmness with no tcu to worry about. You'll have nearly an instant shift vs the slow tcu shift. Turn the switch off and you can let your tcu take back over.
    For people with modified setups, H22 swaps and or turbocharged platforms as well, this could litterly shave 1-2 seconds of any strip pass. This means your auto will finally shift quicker than any 5 speed can with better accuracy and control. You won't have a TCU pulling timing every gear shift as well, which will be a big boost in torque upon shifting. No slipping gears means less heat, and it will give your transmission a longer life.
    Full line pressure will be for WOT passes on street or strip your choice, and should not be used for everyday driving, as it could hurt your pump, Although the slightly lower settings will be a very nice upgrade without having to tear your transmission apart. A Few wires will need to be soldered in, and for the most part idiot proof installation.
    You have no reason to doubt this, At this very moment this is whats being intigrated into my DSM as well, Because with my new power levels I am having some serious slipping at high end gears, and these trannies are good till about 450 whp before they begin to slip. With this mod I am not having those issues anymore.
    The identical setup is what i am making for the cb7 it's not more complicated, just slightly different because of how the transmission is designed. Full testing is going to be undergone to insure a lifetime of flawless function.
    This is the real deal, and may actually cause me to have to become a supporting vendor once complete.
    I would like to see some input from members on here that have automatics.
    Please any 5 spd FTW fanatics, render a little respect for an opened opportunity for the CB7 world.
    This modification with a level ten torque converter and a boosted F22 could make one massive beast.
    The price will be competitive and the design pattant. I hoping to stay under $200 or lower per unit.
    Post comments or a list of interested persons.
    This will be a KDI product.
    for auto transmission issues click here.
    http://www.cb7tuner.com/vbb/showthread.php?t=179566
    "Self Renewed"
    Sounds like a really good idea and a great deal at that. Good luck with your testing.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      sounds good.... but its on topic
        you have a point, let me find a better suited spot.
        "Self Renewed"
          x2
          I think it's interesting. If I chose to turbo it would save me the trouble of putting a 5 speed in.
          When do you plan to have it done?
          MRT
          sneaky motherfucker
            good price. im guessing this would work with CD Accords as well right?
            no
            Accord turbo kit under $2k here
            $30 HID kits here Thread
            "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
            "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
              I can't be 100% sure, as wire colors will be different, but with the right schematics, The setup should be able to also work with them. I'll just have to check on some of their solenoids to see if they are on the same voltage ratings.
              "Self Renewed"
                I'd be interested in this project. I'm all about 5 speeds, but I've seen some nasty turbo automatics tear up the strip. I'll give it a whirl if you can make it happen.
                You're such a dumbass, the world ends on saturday...
                  Can you integrate launch control?
                  MRT
                  sneaky motherfucker
                    Launch control is decided by the ecu, not the tcu.
                    If your wanting to stall higher, a level ten performance stall converter will be needed.
                    If your asking about a trans brake, the answer is no, as of right now, these aren't built like your big V8 cars.
                    "Self Renewed"
                      in action
                      http://www.facebook.com/video/video....=video_comment
                      http://www.facebook.com/video/video....50218799886665
                      "Self Renewed"
                        Very nice work! I like the thumb actuated shift paddles
                        MR Thread
                          eh... do you have any non log into facebook videos.
                            That's good stuff man. I like what I see so far. I can't wait to see a better video of it in action.
                              I wasn't even sure if my camera was recording.
                              I'll be getting on a straight stretch and trying to mount the camera so i don't have to hold it. I'm unsure where to mount it though. We'll see.
                              Once I integrate the digital display into my gauge cluster where the OD light comes on, I'll be hiding the control box in my armrest.
                              I don't have photobucket,
                              here is youtube.
                              http://www.youtube.com/watch?v=sMeuK...er_profilepage
                              http://www.youtube.com/watch?v=5b3bg...er_profilepage
                              "Self Renewed"
