When I go to the junkyard I bring my favorite tools with me. Please list what's in your tool bag when you head out there. I generally pay my admission and walk in empty handed and spend 15 minutes looking for items I want then return to my car and grab the items I need to remove what I want. My local junkyard doesn't allow power tools, but if your junkyard does that is cool.
Here is my list:
18" solid swivel 1/2" breaker bar
cheater bar to extend breaker bar
1/4" drive ratchet
3/8" drive ratchet
1/2" drive ratchet
ratchet extensions
ratchet adapters
hacksaw
wire nippers
full metric socket set
full metric deep socket set
metric ratcheting offset box end wrenches
metric box end wrenches
hand held MAP torch
3 different sized pry bars
magnetic tray
9v battery
speaker wire
3 jaw puller
2 jaw puller
ball joint splitter
sterring wheel puller
hub puller
5lb slide hammer
inner bearing puller
seal removal tool
PB Blaster
manual impact screwdriver
rubber mallet
3lb sledge hammer
flat head screwdriver
philips head screwdriver
razor blade
pliers
adjustable wrench
vice grips
chisel
30mm socket
36mm axle socket
Feel free to share your list as well or make suggestions. I may add to the list as I remember what tools I do have and what I generally bring with me
Here is my list:
1/4" drive ratchet
3/8" drive ratchet
1/2" drive ratchet
ratchet extensions
ratchet adapters
hacksaw
wire nippers
hand held MAP torch
magnetic tray
9v battery
speaker wire
3 jaw puller
2 jaw puller
ball joint splitter
hub puller
5lb slide hammer
seal removal tool
PB Blaster
rubber mallet
3lb sledge hammer
razor blade
pliers
adjustable wrench
vice grips
chisel
30mm socket
36mm axle socket
