I've replaced bulbs in both sides of the car however the car headlights are still very low on both settings any suggestions or the only fix xenon type headlights..?
HeadLight Issue
check the headlight fuses in the fuse box in the engine bayOriginally posted by CB7Austin View PostI've replaced bulbs in both sides of the car however the car headlights are still very low on both settings any suggestions or the only fix xenon type headlights..?
Only thing i can think of having the headlights dim that way..
Like said, check the voltage at the bulb plug to a good ground . If the voltage reads good, then test again using the ground in the bulb plug to see what voltage you have. If test one shows good voltage then most likely test two will show lower voltage telling you that you have a poor ground connection. Look for a wiring diagram to show you all ground points so you can clean them. If test two shows no drop in voltage from test one, then I'm stumped. Lol.
