Sometimes it goes off for 2 weeks and stays on for days then goes back off? Ideas?
Random brake light out reading on gauge cluster
I'm having the same problem in my EX
Everyone is going to say check the 3rd brake light but to be honest i do not think its part of the brake lamp light system. I think only the 4 rear mounted lights count.
Supposedly its the brown/black boxes on the back of the taillights that go bad and cause this problem, I've never looked into it though i just live with it.
Originally posted by Tippey764 View PostSupposedly its the brown/black boxes on the back of the taillights that go bad and cause this problem, I've never looked into it though i just live with it.
Cleaned them up and applied electrical grease, that fixed the problem for me.
My 5.7 LS1 Holden Ute
Another possibility could be different resistances from different brake bulbs. I’ve never experienced it myself but have heard about it as a possibility as to why the light turns on.MRT's:
2001 Acura CL
1991 Honda Accord SE
Originally posted by Bad_dudeIf you turn it all the way counter clockwise, you activate the after burner full throttle. Lol. Then when you press it, boom, fast as the T-Mobile data plan chic.
i have the same problem in my DX. i noticed that water was leaking into the gab between the lights on the driver side. noticed the black cushion was soaked in water and it was touching the plug which plugs into the brown box. found out it had alot of corrosion. so possibly could check out to see if it gets wet back there.
Originally posted by ghowell6 View PostAnother possibility could be different resistances from different brake bulbs. I’ve never experienced it myself but have heard about it as a possibility as to why the light turns on."There is nothing wrong with you that an expensive operation cannot prolong."
Check your tail light gaskets if it keeps happening, and check if your bulbs have a filliment burnt out or something"If you're going to put money into a car to increase performance or appearance, why go cheap? People don't need to go all-out... but put a little effort into it, or don't bother doing it at all"-Deeve
Ride http://www.cb7tuner.com/vbb/showthread.php?t=187088
Brake light dash light on
I had this problem also. I had to locate the brake light sensor in the taillight assembly remove it and replace it with a new/used brake light sensor cut the wires and butt connect the new/used brake light sensor in place. Then put new weather strip to stop the water from coming in and destroying the new/used brake light sensor. This may help you out.
i had this problem yesterday but i also noticed that my gear selector would not move and did not make the clicking noise when i pressed on the brake peddle .
my fix was i replaced brake switch brake still did not work nore did the shfiter . i replaced the lock solenoid for the shifter . now the shifter and brake lights work.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
