Originally posted by H22artman
View Post
Hood Spacers....
Originally posted by deevergote.......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
Originally posted by blackedout View Postyea stopped is where it will seep out. In the heat you can see the heat come out of the back of the engine bay when your stopped but i mean how long are you going to be stopped?? you are in motion more than you aren't.. do the benefits outway the costs? just ask yourself that one
Originally posted by deevergote. View PostThe hood standoff actually doesn't do much but cause turbulence under the hood. Your engine bay is designed to have some airflow from the factory (or else the air would pass under the radiator, and not through it into the engine bay). While the car is in motion, the engine bay gets all the airflow it needs by having the air drawn out under the car. When you raise the hood, you're then creating a sort of vacuum with that small space up top, which may have ea negative effect on the intended airflow characteristics of the engine bay. You are now sucking some of that hot air back up into the bay, but due to the fairly small opening, it's not letting it all out.
ok lets make our mind up is it good or no?......does it effect fuel, does it harm the engine bay?
Originally posted by MclovinRR View Postonly if it where legal and safe lolR.I.P Rex 10/10/97-08/06/09
There aren’t enough words in this world to say how much you will be missed. love you buddy!
Originally posted by Sobeman81 View PostUMMM. you are stopped or moving slow during construction season in the summer in Chicago quite a bit. So for me, that would be a HUGE help. So to answer your question, YES the benefits out WEIGH the cost.
I can see what you are saying Deev, and agree to a certain extent. But, what about cowl induction hoods used on the hot rods back in the day? Isn't that the same concept as using spacers?
Additionally, just because the hot rod guys do it doesn't mean it's the best idea. Back in the day, the hot rod and muscle car guys were no different than us. They're not engineers.
If you want to do it, do it. But it's not helping anything. Arguing this "fact" is just like telling me that the Turbonator is saving you gas. You can argue flawed concepts all you want. It doesn't change the reality that it won't do a thing.
As for wind tunnel testing... what the hell would that prove? That the raised hood is more aerodynamic? The car is not running in a wind tunnel, and the engine is certainly not under load.
Who cares what the temp under the hood is. What matters are the temps your engine is getting in. I highly doubt there is any significant difference, especially when cruising. At a stand still I'm sure the hot air will escape with the hood opened like that, but that's it.
Originally posted by d112crzy View PostWho cares what the temp under the hood is. What matters are the temps your engine is getting in. I highly doubt there is any significant difference, especially when cruising. At a stand still I'm sure the hot air will escape with the hood opened like that, but that's it.Last edited by flcb7; 10-09-2008, 10:12 AM.R.I.P Rex 10/10/97-08/06/09
Originally posted by slammed4thgen View Postjust admit its for looks guy
I posted in the other thread I'll post here
1. engine bay and outside temps equalize at 10-15 mpgs
2. this does nothing while sitting still
3. 10 degrees cooler is not significant and I doubt that either way
4. you will most likely increase wind resistance by doing this
5. hondas are damn efficient as is
this mod is pointless...do what you want to your car, but this IS pointless____
