a/c problem
    a/c problem
    when i turn on the a/c while the engine is NOT running, it's fine. but when i turn on the a/c with the engine on, the engine starts to stutter and it feels like its about to die. the rpm drops and goes back up. What's wrong? Also, theres a click sound everytime its about to drop rpms.
    Your AC doesn't work without the engine running. All you're doing is turning on the blower fan. The engine has to be running in order to spin the AC condensor. Your car needs a tune-up and an AC check.
      the click sound is the relay latching to turn on the compressor for A/C. rpms drop because system is not compensating for additional load. check air boost valve & do regular tune up.
      Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
        Also, the a/c relay has a pressure switch. If your a/c doesn't have the right amount of pressure the compressor won't even engage. I would say that your refrigerent pressure is low, and that you need a tune-up so that your idle stays at a more constant rpm. It's normal for your idle to drop when turning on the a/c cause you're adding more load to your engine. However, I believe your ecu should see this and compensate by raising the rpm's.
        If you go to have it recharged with the original R12 refrigerant it will be expensive, but more compatible with the cb7 system. I suggest having them put dye in the system so it can be checked for leaks.
        Your other option is to retro fit your system to the r34, which is the current refrigerent used cause it's cheaper and easy to convert. Only downside is that you may notice it's not quite as effecient. I had my 91 civic si converted and thought it worked pretty well...till the compressor blew out. That's a whole different story.
        http://www.cb7tuner.com/vbb/showthre...=1#post1823428
        My Custom BB6 Dash Swap Thread
          my 92 h22a accord does it same thing, when a/c kick on it will drop down rmp, i'll guess when the car got old, it does that, same as my crx i used have
            my 91 h22 does nothing but blow hot air when i turn the a/c on
              Okay so I checked it again. One of the fans aren't spinning when the A/C is on. Do I just replace the fan or is it something else?
                Which fan comes on? One fan will be off unless your engine temperature is high enough to turn it on.
                Have someone help you by sitting in the car turning the A/C button on and off (turn the fans up as well). the passenger side fan should be tied to that button.
                1992 Prelude S w/swapped H22A
                  Driver's side is A/C condensor fan. Wired straight to the condensor fan relay mounted to the driver side fender.
                    Actually, it's the other way around, I *think*.
                    Also, both fans come on when the A/C is on, no matter how hot or cold the car is.
                      Condensor fan is on the driver side, it has a smaller shroud. The one on the passenger side is the radiator fan. Both should come on when you press the a/c button. Instead of converting to R134a, try Industrial Enviro-Safe 12, it cools better the r12, contains no cfc's, and is safe for all r12 systems. Freeze-12 is also a good alternative to R12.
                        hey pewyee, i can help u fix that idle prolbem, i just did my front motor mount coupe days ago with 3m windo weld, it fix most the idle drop problem, u should do the front mount it help, my idle got alot better and shift alot smoother, what year is ur car and have u ever change ur front mount?
                        its very easy to remove and fill, i let it dry for 48 hours
                        http://www.cb7tuner.com/vbb/showthread.php?t=118013
                          Oi. BOTH FANS COME ON WITH THE A/C ON. END OF STORY.
                          Go out to your car when the engine is cold, turn your fan on with the A/C button engaged, and turn your key to the II position. Pop your hood. BOTH fans will be running.
                          Both my Accords were like this, as well as my two friends Accords...
                            Mine too!
                              Agreed, the engine has to be runing to turn the a/c compressor, therefore the a/c doesnt work without the engine running. Also the A/c has a low pressure switch and if your refrigereant is to low it would not turn on at all. The clicking sound you are hearing is the compressor clutch kicking on which is normal. An evac and recharge is in the future for your car and possibly a retrofit if it has not already been done, from r-12 to r-134a
