I KNOW the f22 can be bored.
N/A G22 vtec
Bore it over 1mm and get standard bore rsx-s pistons..
Compression is your friend when trying to make power all-motor.
If you find out if the F22A can be bored let me know. That would save me time and money with sleeving it.
and d112crzy thanks for the info but do u think a regrind would be better than a name brand camshaft?
and also thanks to who all posted
Originally posted by Brandoncb7 View PostI used to read about the G22 a while back but it's been a few months. As far as I can remember though I thought people were having problems with the reliability of this motor? Or maybe i'm just ignorant/misinformed......
Originally posted by deevergote. View PostThe reliability issues often come from a lack of experience, or a lack of care when building a frankenstein motor. Done right, they can last... but such a drastic modification opens up a can of worms when it comes to potential problems, and it takes a lot of care and knowledge to be sure to address each one. I generally criticize franks because people that want to do them have nowhere near the level of experience necessary... Most harsh words about them have been from me
another thought does the f22 crank and rod combo in a h22 net more power??? granted you have to buy certain pistons for the sleeves in the h series block but wouldn't this make 88mm available to use and still give you the torque you want??? muchless the less headache of mating the h22 head to the block dealing will the water pipe issues and other little things.
Originally posted by d112crzy View PostF22 rods/crank fit perfectly in an H22 block. You'll need to get the rods pressed off the f22 pistons and onto the h22 pistons though.
15k miles and going strong still with my h23 vtec.
have you dynoed it yet from what i have read in the past the g22's lay down around 165ish with stock guts
Originally posted by deevergote. View PostI had people come 2-3 hours to help. The FL crew is badass... you'd get help if you asked for it!
I heard you came to Palm Beach, you little ninja, you.
As soon as get my H22, I'll hook up the BBQ and beers at my place. I already have a buddy from FLaccords that will help me out, I'll let you all know was sup.... G22 is interesting, the only thing I don't like is hat it's not as "plug & play" like an H22 would be....
1993 - CB7 10th Anniversary edition
1988 - DA3 Special edition
Originally posted by Orlando_CB7 View PostAs soon as get my H22, I'll hook up the BBQ and beers at my place. I already have a buddy from FLaccords that will help me out, I'll let you all know was sup.... G22 is interesting, the only thing I don't like is hat it's not as "plug & play" like an H22 would be....
That's the exact reason i'm not looking into the G22 anymore because I need an easier one for my first swap. I just think I would screw something up and that if I did the H swap I would come out happier.
