when i start doing over 50 mph and i start hitting the brakes then i can feel the shaking in the stearing wheel. the faster i go the harder it shakes. its not bad but kinda scary. when i hit the brakes even harder the shaking quits.. any ideas why it doeas thats??
car shakes when braking
whens the last time you replaced your brake pads? and maybe yours rotors are due for a changeYou don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
I'd highly recommend getting your rotors checked out because by the sounds of it you have warped rotors. I'm not saying that you definitely have warped rotors but from what you're saying that sounds like the problem. If the car shakes when not under braking at speed then I would look into possibly re-balancing your wheels.
Originally posted by Mike1357 View PostI'd highly recommend getting your rotors checked out because by the sounds of it you have warped rotors. I'm not saying that you definitely have warped rotors but from what you're saying that sounds like the problem. If the car shakes when not under braking at speed then I would look into possibly re-balancing your wheels.
Definitely NOT definitely rotors.
If the shaking is all in the steering wheel, it's almost always tie-rod ends or ball joints, but usually tie rod ends. Ball joints will make clunking noises when turning or driving over rough road. Warped rotors will pulse through the brake pedal.
Look for torn boots and easy moveement when you try to move them by hand. It's more something you learn by experience. If you move them by hand, and then check the new ones after install, it'll help you feel the difference in the future.
I'd say most likely, rotors. reason you don't feel it when u hit the brakes hard is because the rotors aren't passing through the pads, meaning the rotor has stopped. Pulsing in the pedal usually means warped rear brakes. You cannot "see" if your rotors are good or not. You need to take it somewhere and have someone put a dial indicator on it to read the run out on the rotor. That is the only for sure way of knowing. Also if your rotors are indeed warped, have them mic out the rotors as they may still be thick enough to be turned.
WTB: rightside jdm 1piece headlight or just glass.
hey i just got a 1990 cb7
and the car had been just collecting dust for bout 3months
i turned it on to check it out and fired up right away
but when i would drive it sometimes it would shake a lil but like in 1st gear
idk y and none of my gauges are working if u can help i would really
appreciate it thanx
only the rpm gauge works
