Am I gonna die??
    Am I gonna die??
    Ok, so Ive taken my trans out like 5 times and this is the first time Ive encountered this problem. My CB makes this weird Grinding noise (NOT CLICKING) when in motion making left corners,(the noise originates from the pass side of car) not CV Boots but like something just isnt right. Now Ive inspected all of my suspension and yes some things need attention but this is weird. Left curves on any given road feel really unstable and as if the tire is about to fold over. Also the pass front tire is wearing on the outside to the tune of 2 tires a month. OH I almost forgot I mentioned taking the trans out because for those of you have done it, know that you have to remove the Right Radius rod. My first four times removing the trans i didnt remove it I just moved it, this time I actually took it out and now I think that has something to do with it, does it. This is my weekend warrior grocery getter and kid carrier so serious responses please. AM I GONNA DIE!!!
    Sounds like your axles may not be installed completely. People often push them in enough to put everything back together, but not far enough for the little snap ring to click into place.
    You shouldn't be at any serious safety risk, as long as you don't abuse it... but I'd still take everything apart again, and make sure those axles are in securely.
    Other than that, inspect all bushings and boots. If your ball joint boots are torn, you MUST replace the ball joints. If they fail, then you most certainly could die!
      Hub bearings??
        I was thinking bearings too.
        Water is one of the primary cause of wheel bearing wear because it can rust up the bearings easily, if the seals fail. You can check them by jacking the car up and wiggle the wheel in a rocking motion. Serviceable bearings generally allow slight movement, about 1/8 of an inch in free play. Anything more than that will require retightening the bearing, servicing the bearing or replacing the bearing. Our cars have press-in style bearings, they do not come as a hub assembly. Hope this helps
        life is good.
          Originally posted by plee3 View Post
          Hub bearings??
          X2, Did you tighten the axle nut tight?
          A loose axle nut can cause a similar noise as that holds everything together.
          My 5.7 LS1 Holden Ute
            Honestly I didn't know where to begin so thanks for all the info. Would it being out of alignment cause the wear of the tire or the joints. That probably seemed like a dumb question but my steering wheel is centered and my car only drifts right ever so slightly. Hub bearings, do they kinda hum like you bought some cheap ass tires? If so that's one of my problems right there but. I'm off tomorrow so imma check it out. Thanks
              Our cars have non-serviceable bearings, yet another japanese innovation!
              Your wheel will wobble if the bearings are bad, I discovered this when rebuilding my front end
              1992 Accord Wagon (RETIRED)
                why on earth did you have to remove it 4 times? Did you do a auto to 5spd swap or something? b/c if you did and didn't change out the mounts by either rewelding the bracket or didn't buy the ESP Auto-5spd mount, then your trans/engine will never sit right and could be causing you all the problems.
                  ask any lifetime mechanic. if it pulls, it pulls. no matter how much it does, it still does.
                  definitely go back through and pull everything apart as you did when removing the tranny except actually removing it. then put it back together piece by piece carefully paying close attention. make sure everything is tight and in good shape. you'll find the source eventually.
                    You may just have a bent backing plate that is rubbing on the rotor, but as for the question if you are going to die. You need jack up the car and check out the front end for play. From the sound of your extreme tire wear you need an alignment or something is loose or broken in your front end. You also may have improperly installed or forgot a bushing in the radius rod. You said that you know that some things "need attention"... what parts are you talking about? When I tackle problems like this at work I fix what I know is broken first. Check out your front end first and determine what needs to be replaced. Then when its tight get it to an alignment shop I have never heard of someone having to replace two tires a month due to wear. If you are going to use this car to haul your children you should bring this car to a shop and get it looked at before putting your kids in it.....I hope this helps
                    My CB7 http://www.cb7tuner.com/vbb/showthre...hlight=phalpin
                      Im gonna probably rebuild the front end on it and I'll probably need help so if anyone is in the Florence Muscle Shoals or Tuscumbia or attend UNA in North Al hit me up and let me know$$$$$$$. I WILL PAY$$$$$$
                        i had this prob before. had to replace the ball joints.
