As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
seat belt problem
    seat belt problem
    my seat belt was working a couple days ago and one day I closed my door and my seatbelt stopped half way and does not move any more. I don't even know were to start with this one. Please help
    Go to the dealership. Our seatbelts have a lifetime warranty. they should be able to assist you with your problem.
      i once read on here that seatbelts have a lifetime warranty; (at least against mechanical failure). all you need to do is go to a honda dealership and get it fixed.
      its free according to my memory.
      it would not hurt to give them a call and explain the situation
      but you might want to check your fuses.
      check the switch that tells the car the door is closed/open
      good luck
      edit, plee3 just squeeed in the answer before me
      i found this in a post by "accord=inspire?"
      Originally posted by accord=inspire? View Post
      thats what im talking about. honda should not have lifetime warranty if a car is 20 yrs old and cant even get a seat belt fixed. i think the SM is not trying hard enough or doesn't care. i am going to get in contact with another honda dealer after i get my car back from a head gasket job.
      can anyone tell me how to get in contact with Main (corporate) Honda ? just in case another dealership BS with me again?
      _
        good luck
        KB7 Accord stated to check your fuses. I would do that first. I think they are labeled passive L and passive R. (I think. some one chime in if Im incorrect) in the fuse box under the hood.
          You could also check the seatbelt module that is under the passenger seat. I do not know if this one module controls both seatbelts or just passenger. It's about $10 at the junkyard.
          I asked Honda once if they would repair my seatbelt under warranty, but they said only if it had ripped.
            that is very conflicting information from my research, the particular thread i gathered my info from stated that his honda dealerships could not and would not fix his frayed seatbelt, because
            A) they only covered mechanical
            B) they could not find any part to fix the strap, as in the strap no longer exists
            this all sounds like honda is trying to get away with not covering their warranties.
            the thread i found
            _
              the thread i found
              I agree, it is conflicting. They said as long as the strap still holds and has no tears, then everything is ok.
              In the meantime, you can roll the seatbelt to the back of the track. In case you don't know or haven't, there is a plug next to the passenger sear in the frame. Pop that out and put a hex key in there and turn.
                IFuses are fine, ive noticed that when I open my door when the car is on there isn't no more chime no more. But my cluster does show that my door is open. I wonder if that has something to with the problem?
