Sway bars..?
    Sway bars..?
    ok Im looking at suspension in my car and where i can tweak to get rid of body roll and such...
    My question is..
    I have a 1991 DX coupe... do i have front & rear sway-bar?
    how hard is it to add the other if only one is present
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    the sway bar thread
    your sway bar in the front is 22.3 mm (you wont find that info in the thread i linked, but i promise you its the bar you have)
    you have no rear
    you can upgrade the front sway bar to the ex/se bar, which is 25 mm, however you should focus more on the lack of the rear one first.
    the ex/se rear bar is 14 mm
    there are other cars you can grab the rear bar from, and i think the biggest you can et that will fit is 16, before you have to go aftermarket. but from what i have read on here, its easier to instal an after market rear bar than the oem.
    also a thread to read would be this one, it definitely will help you to tune your suspension
    good luck
    i checked you mrt, and if you really want to get rid of body roll, stock height is kind of a big problem for our cars, once you drop about 1.5 inches you will definitely feel a dramatic decrease in body roll, it gets better the lower the car is
    _
      Yes you only have a 22mm front sway bar as posted above
      To add a stock rear sway bar you will need the whole rear cross member off of a car with a rear sway bar. The brackets to mount the sway bar are bolted to the cross member but it has nuts welded inside the cross member to hold the bracket on. So you cant really add the bracket Stock rear sway br is 14mm. It came on ALL 1990-1993 EX's and SE's. A stock rear sway bar was also included on 1991-1993 LX wagons
      The 10th AE does not have a rear sway bar
        Originally posted by KB7Acoord View Post
        the sway bar thread
        you have no rear
        good luck
        Yeah i had my car dumped on some sleeves i had from a buddy the body roll was next to nothing.. but the drop was to steep for me.. Im planning a complete suspension overhaul...
        How hard is it to change crossmembers for the rear so i can add that one as well?
          just spend a bill sixty-ish and get a progress rear sway bar set-up. i got one and it makes a world of a difference compared to no bar at all
          8 Accords so far:
          '81 SE Sedan(1st Gen), '83 SE Sedan(2nd Gen), '89 SE Sedan(3rd Gen)
          '89 DX Sedan(3rd Gen), '92 LX Coupe(4th Gen), '92 EX Wagon(4th Gen)
          (3rd gen parts car) I'm currently Driving a '14 Accord Sport 9th Gen
            Does this require the factory mounting spots.. or would it go on my DX?
              the sway bar thread
              you have no rear
              good luck
              Good info.
              Just to clear one thing up though, the decrease in body roll is usually due to the stiffer spring rate of aftermarket lowering springs, rather than the lower ride height.
                ?? any one... can i mount the progress rear sway right up to my DX?
                  Don't know about the progress bar, but a stock crossmember is mounted with four big bolts to the underside of the body, and two long bolts that connect the control arms to the rear hubs. Find an EX in a jy (if you take the hubs as well you can have rear disk brakes). Make sure you have the alignment checked after the swap. If you were near OH, I could provide a set of EX sway bars including the rear crossmember.
                    from what i think i remember, its actually easier to install the progress sway bar on CB's not equipped with disk brakes, i cannot remember exactly why though, sorry; however since the OP has a DX i guess he will not need to worry then.
                    ill try to find the thread that i have read, it wil be a little difficult as i have read ALOT of suspension threads, but i think it was a diy.
                    and to "TheNextEpisode", that is an excellent point
                    here is the diy
                    so i am pretty sure it is the right thread, however i must have remembered incorrectly
                    heres a quote
                    " Some modification of the brake line mounting tab may be required (mine did not, so it may be a rear drum thing)."
                    any way, i think i am done here, good luck
                    i was closing tabs on my browser and found the instruction manual on how to instal the bar
                    here you go it seems to be straight from the comapny "Progress" website
                    _
                      i have been trying to get any info for a while now i just gave up but what way would be best to go i drive lots of canyons twisties an country roads i have strut bars lowering springs 2 in drop tokico shocks would the progress sway bar be best ? or stock ex o an i have a 91 lx drum in rear
                      This thread is over a year old, you fucking retard.
                      i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASS
                        found this
                        its a thread titled "ex swaybar vs. s/t"
                        nothing golden in it, but some good info is there
                        _
                          alright cool bro
