Help with a plug
    Help with a plug
    Anybody know how to get this thing unstuck. I really can't figure it out w/o breaking it or splice my wire harness to it.
    IridiumCore
    HCK-The Beginning
    Your drunk she doesn't look that good.
    Is that the ABS pump? I was trying to guess and that's the best I can come up with. Maybe transmission
    MRT
    sneaky motherfucker
      try using penetrating spray...and gentle try to work it off
        is that a rubber boot over the end? you should be able to roll it back and get a better look at where the release tab it. Sometimes it helps to press the release tab firmly while pushing on the plug before pulling on it to release it. This works pretty good for me when unplugging harness underneath cars that are caked with dirt.
          Yeah i pulled it back but it felt like it was metal all the way around. Crap, maybe you unscrew it. Dunno but I'll look for the release tab. Thanks and thanks everyone.
          IridiumCore
          HCK-The Beginning
            Its the reverse sensor.
            It doesn't unplug - You unscrew it.
            At the base you will see the flats on it for a 17 or 19mm spanner to fit.
            My 5.7 LS1 Holden Ute
              Yep, reverse sensor it unscrews out and about 6-8" up there are 2 single wire plugs that pull apart. They are reversed so you can't switch the wires up.
