Starting Prob
    Starting Prob
    I have a 92 coupe with about 225000 miles, Its my daily driver, i am having an issue starting the car, New battery, alternator, dizzy, has a new PCV valve, fresh oil , new battery cable, new sparks, everything has been maintained, I have checked the battery and the alternator several times, the plugs and almost everything else myself ! Doesn't make sense, it just keeps on cranking and after 3 to 6 times it starts, normally its takes one crank and it starts right up. All the connections are good, had all the parts listed above changed abt 2000 miles ago. and the air filter too.
    Any ideas ??
    Thanks in advance !!
    has it been cold lately?
    my cranks longer in the cold (below 20F) before it lights off.
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      How long do you hold the key in the start position each of the 3 to 6 times? When you changed the distributor, did you reset the timing? Ever changed the fuel filter? Do you have a gauge to check the fuel pressure? Once it starts, does it run normally?
        Well just as usual, about a few second, maybe less, yes i did reset the timing, and yes i have changed the fuel filter, i forgot to add that !
        No i dont have the gauge to check the fuel pressure, Once it starts, it drives like new, never fails, and if i stop and start it again even after 5 min, it starts right back, but if its about 30 min or so, then i face the same issue.
        Thanks
          Yes it has been cold ! but i normally don't drive when it snow's and the car is in my garage, well talking about cold, it never fails to start, maybe once in a while it starts on the second try.
            Try holding the key in the run position for a few seconds before you crank it over to the start position to let it pump fuel all the way back up to the injectors. Most likely, it's just sluggish and cranky because of the cold. Mine takes a little longer to start when she's cold.
              Tried it, still the same, makes me wonder ! what else needs to be replaced when almost everything is new !
                Maybe the starter? Check if its tight? Most likely its just the cold.
                  Found out the issue, My spark wire cable was replaced and it started just fine,
                  thanks the tips
