if my vacume line going to my map sensor were to collapse under high rpm or normal driving this should cut off the vacume going to the sensor and the car should quit right? then at idle there is less vacume the collapsed hose will open and the car should start running again? i'm just wondering if this thought is correct or on the right path to solving my accord problem
map sensor vacume line, collapse?
Not impossible, not very likely either.Originally posted by peekin View Postif my vacume line going to my map sensor were to collapse under high rpm or normal driving this should cut off the vacume going to the sensor and the car should quit right? then at idle there is less vacume the collapsed hose will open and the car should start running again? i'm just wondering if this thought is correct or on the right path to solving my accord problem
Whats the deal w/the car? Whats wrong w/it? Have you considered replacing the vac line, to rule out this possibility? Vac lines are about .50Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
If the vacuum is cut off from the MAP sensor it should throw a code and the check engine light would come on before it quit.
There is more noticeable vacuum at idle with a closed throttle than at high RPM with an open throttle. However, if you were to push the car up to a high rpm and then close the throttle rapidly. That would cause a vacuum spike and a drastic reduction in fuel should follow. But it shouldn't stall or quit, the ECU is equipped with what is called a fuel cut. Usually activated when it reads high vacuum (MAP) with a high rpm (VSS).
What is the problem that you are having? Is your car cutting out under certain load conditions or throttle positions? Is the check engine light on?
yea it will just cut out like its not getting fuel, it will sit there and idle perfect all day but once you start driving it will work ok for about a minute then it will just die, if i press in the clutch the tach will go down to idle it will spit and sputter then idle fine, drive along for another minute just fine then die again
When was the last time you did an ignition tuneup? It's probably not your entire distributor, could just be your cap and rotor, maybe even just be your plugs and wires. It kind of sounds like you just need an ignition tune up.
Spark plugs - NGK
Spark plug wires - SUMITOMO
Distributor Cap - TEC
Distributor Rotor - TEC
You should also test your coil (TEC) and ignitor (NEC/ELESYS) as well.Last edited by GhostAccord; 02-15-2011, 01:55 PM.
