The place I would start first would be the engine. Work from the bottom up, oilpan to valve-cover. For those aspirations, your going to need a sleeved & braced block, forged internals, headwork, valve-train upgrades, a big turbo, and a solid tune. For transmissions I would consider using the longer geared f22 transmissions as you will remain in boost for longer. You might also want to look into water-injection if you plan on running on pump gas. That should give you somethings to work on. When you have the plan, or questions answered to help you with that plan feel free to post, and we'll be happy to offer commentary.
Building up F22a4
That all depends, are you building a naturally aspirated motor or a turbo charged motor?Originally posted by vzig View PostOk, so new question...
should I go with dry sleeves or try something different and go with wet sleeves?
I haven't heard much chatter about wet sleeves so I'm curious if anyone has used them?
and maybe a good brand to look into?
Darton M.I.D.....a dry sleeve is really only a replacement liner. If you want to go over bore or put the boost to your engine a closed deck wet sleeve would be the way to go. Installing a set of wet sleeves is not something different. I would say 9 times out of 10 when you hear someone refer to sleeving their block. They are talking about installing wet sleeves.
Please use the edit button to add to a post, rather than posting repeatedly.
If you want to ask about the transmission, make a new thread about it. Your transmission swap is NOT part of a motor build. This site is intended to be a searchable database of information, so when someone wants to learn about a transmission swap, they will not be searching through threads about "Building up F22A4".
well I wouldn't know without asking questions first... I suppose there a lot of people who are new who just KNOW everything huh? I guess I just pictured this site to be a place where I could ask questions and get answers instead of people talking down to me and making me feel stupid.
Thanks to those of you who actually helped its appreciated.
I'm going to look more into that
