help my accord ex keeps over heating
    hello all,
    i have a big problem. my 90 accord ex keeps over heating. i changed my timimg belt and water pump, that's were my problem started. i was told there is " air " in my cooling system. i never heard of this so i removed my thermostat. thinking straight coolant should do the trick. all my fans work. i just don't wanna melt my head, any help would be greatly apperecatied.
    [IMG]http://
    Have you checked for any leaks, I recently had one and it made my cb7 overheat.
      Actually this is happening to me too ATM. I had a huge leak of coolant and think my radiator hose is busted or the entire radiator itself. As said, check for any leaks. Tow it everywhere.
      1993 10th Anniversary MRT
      Originally posted by The G-Man
      For that money, yes. But my dick isn't big enough for that shit.
      List of all my cars to date
        Yup get it pressure tested.
          i have no leaks, and pressure tested the radiator. nothing leaked and my hoses; are in good shape. thanks for your input guys. keep 'um coming.
          [IMG]http://
            get the air out. and put the thermostat back in.
            COUPE K24
              Maybe a radiator flush could solve the problem.
                how would get the air out of the system.
                i have a 92 accord lx that looks like crap but runs very good. until it took a dump on me too. nothing like these 20 yr old cars!
                [IMG]http://
                  theres an air bleeder on top of the thermostat housing. open it up slightly and let the car run for a few minutes. should let it all out.
                  COUPE K24
                    Or get a radiator cap with the safety valve or with CAUTION with the car warm remove the cap and let the air out that way. Theses ways work for me every time.
                    STANCE|WORKS
                      I have had the same issues with overheating as well. Opened up the bleeder valve and let it run for about 5 minutes until i had a nice consistent stream of coolant comeing out and havent had an issue since. Quick and simple and easy overlooked.
                      1996 Honda Shadow VT1100C
                      Sold
                      1993 Honda Accord 10th Ann
                        I've found that if I raise the front of the car (ramps or with a floor jack) when filling the system, it leaves very little air in it. Still, bleed it at the thermostat housing.
                          thank you for the info guys, i;m no good at working on cars but that seems easy enough.
                          [IMG]http://
                            don't forget to turn your heart on full blast when bleeding the air out of your system.
                              Originally posted by Leung View Post
                              don't forget to turn your heat on full blast when bleeding the air out of your system.
                              fixed it to "heat" for you instead of "heart".
                              92ex CB7<-SOLD 93ex CB9shiftingshift73C10
