or..............http://www.daymotorsports.com/proddisp.php?ln=9297
Does anyone know how to make a positive and negative post terminals in the engine bay
To the op, have you ever looked into Jumper Terminals? Alot of RACE cars have the tiniest of motorcycle battery's which don't have enough CCA to turn over the motor, but are there to smooth out the alternators voltages the same way a capacitor does.
They usually mount "posts" in a location thats easily accessable on the car, typically bumpers.
When they want to start the car, they hook up a jumper pack to the posts, and crank.
Heres a quick example image:
Heres a link to them on Jegs: http://www.jegs.com/webapp/wcs/store...umper+terminalLast edited by cloudasc; 04-19-2012, 02:56 PM.
Originally posted by cloudasc View PostTo the op, have you ever looked into Jumper Terminals? Alot of RACE cars have the tiniest of motorcycle battery's which don't have enough CCA to turn over the motor, but are there to smooth out the alternators voltages the same way a capacitor does.
You can mount those terminals wherever you want. Look at that link I posted, there are mounting plates available for the terminals that you can use under the hood. The picture I posted is the most common application of them. That's why they are called "jumper terminals" or "remote battery terminals".Last edited by cloudasc; 04-19-2012, 03:15 PM.
Fuse, solderand insulate all new connections made. I would have use 1/0 gauge to relocate a battery. The only thing you really need is a distribution block. And that would be to jump a vehicle from the front.
To know if the power wire is large enough measure voltage from the frame to the alternators hot wire, then compare that to the positive battery terminal and ground with the car running. If the voltage is less in the rear then the connection is bad or the wire is too small.
Originally posted by oyajicool View PostQuickly glancing over the chart, #4 gage wire should do the job. But, wasn't there a wire/cable included in the re-locating kit?
Originally posted by oyajicool View PostYou'll need all the juice from battery when you are cranking the engine. If you have #2 gauge already, why not use it?
Box to positive terminal on battery all with 2 gauge wire. Ima run 4 gauge wire from both the positive and negative on the battery all the way to the positive and negative post terminals I will essentially be mounting in the engine bay. Then I can just use those terminals in the engine bay to power up whatever I have to power up in the future ( like my msd ignition) using battery power( instead of running wire all the way to the battery I the trunk.) u get me?
I thought;
All you need to do is to relocate the battery.
Run the positive cable from new location into the engine bay to tie with the original positive cable along with the original wire that's run to the fuse box.
For negative, you can run another cable from battery into the bay tie with original negative cable.
Or, ground the negative post of the battery to chassis and ground the original negative to chassis.
There is no need to replace existing ALT out put cable with #2 gauge. There is no increase in demand for ALT power out put by relocating the battery. Unless you replace existing alternator with high out put alternator and, also, increase current demand by installing big amps for sound system. Even then, #2 gauge is overkill, to me.
Current demand is at highest during cranking. That is why you need beefier cable from positive terminal to starter motor regardless of location of battery.
But, what do I know, I am not chassis electric engineer.A&P-IA
I do believe I understood what you were asking. That is why I had suggested to fabricate a junction box within the engine bay to which positive cables and wires could come in and be protected from shorting out to the ground.
The word "junction box" didn't really ring a bell with you, I assume.A&P-IA
Lol you guys crack me up.
Your forgetting that EVERYTHING METAL in your car is pretty much ground. All you need for ground is a nice post off a large bolt. This can be achieved by using flat stock, or just clamping anywhere in the engine bay/frame.
No wire is needed for ground, just pick a place to bolt something to that would allow you to hook things up to it. Like a distribution block. Im sure your local electrical store has one, or just google one.
The only difference with the positive, is that it must not touch anything. And it MUST be fused. Do you have a fuse in the rear of your car at the positive battery post? This should be around the same rating as the main fuse in your car. (100A I think). If not, and that wire gets shorted out, your car is going up in flames.
Bcae1.com check it out. Learn about fuses, or everything there. Great site.
Last but not least solder all your connections. Propane torch for sweating pipe and flux core solder/rosin core solder. They do also make solder paste, which usually comes in a pipe sweating kit, the solder in that kit is usually just solder and has no flux in it. This wont help you for shit, if a newbie trys to use that crap he's gonna end up pissed off with a mess everywhere. The advantage of flux core is your putting the cleaning agent right where you need it.Last edited by MortsAccord; 04-21-2012, 09:23 AM.
