Lol you guys crack me up.
Your (You are) forgetting that EVERYTHING METAL in your car is pretty much ground. All you need for ground is a nice post off a large bolt. This can be achieved by using flat stock, or just clamping anywhere in the engine bay/frame.
If you read my post in regards to ground/negative, I have mentioned about use of chassis as a source ground. I included of running a separate cable for negative/ground into the engine compartment because there may be some electronics/equipment require a ground of it's own. Certain avionics equipments do so. So, I through that in there as an idea.
No wire is needed for ground, just pick a place to bolt something to that would allow you to hook things up to it. Like a distribution block. Im sure your local electrical store has one, or just google one.
The only difference with the positive, is that it must not touch anything. And it MUST be fused. Do you have a fuse in the rear of your car at the positive battery post? This should be around the same rating as the main fuse in your car. (100A I think). If not, and that wire gets shorted out, your car is going up in flames.
I would not install a fuse in the location you are calling for. If the current draw of cranking of engine surpass the current supported by the fuse, the fuse will blow and you'll be loosing all of electric power. Looking at the wiring diagram for the car, there is no fuse installed in the starting circuit, from positive post direct to the starter motor. However, you are correct about the need of good insulation for this positive cable.
Bcae1.com check it out. Learn about fuses, or everything there. Great site.
Last but not least solder all your connections. Propane torch for sweating pipe and flux core solder/rosin core solder. They do also make solder paste, which usually comes in a pipe sweating kit, the solder in that kit is usually just solder and has no flux in it. This wont help you for shit, if a newbie trys to use that crap he's gonna end up pissed off with a mess everywhere. The advantage of flux core is your putting the cleaning agent right where you need it.
I would no recommend the use of torch to solder electric wires of any size. Especially, insulation material used for automotive wires and cables may not withstand the excess heat. Potentially you'll be melting it before you realize. Also, wires and cables are much easier to run through fire wall and bulkheads with out terminals installed. That means you may have to use open flame for soldering terminal ends inside the car or engine bay after the cable is in place. I see this more of fire hazard than running un-fused positive wire/cable from back to the engine bay. If you use proper crimping tool for the size of terminals there is no need for soldering.
Well, this is my way of doing this project if it was mine to do.
