Engine ground location
    Hi, I'm wondering where the battery ground hooks up to on an F22A1 manual transmission CB7? I took the motor out and put it back in by memory (don't ever do that) and have had random electrical issues since then. Now I realize I had both wires from the battery negative terminal going to chassis. I believe one of them is supposed to go to the engine or transmission. Can't find any info on here or google, so I can someone please enlighten me and even post a picture? Thanks a lot
    The battery ground goes to the chassis near the bottom of the radiator. There is also a ground that goes to the thermostat. Then there is another ground that goes to the valve cover. Those are the ones I know off the top of my head, I wouldn't doubt if there were others.
    EDIT: Also check out this thread, it should help you make sense of most electrical problems you run into.
    http://www.cb7tuner.com/vbb/showthread.php?t=184559
      At least on the automatics, the large wire on the battery ground goes to a lug low on the front of the transmission housing.
        Its the same on the MT. You can just bolt the ground any where on the engine/trans then to the frame/battery.
          Thanks everyone. Hooked it to the engine but it turned out the problem was actually a ground next to the power steering reservoir going weak. Rebuilt it and everything is fine
          Bad grounds ruin EVERYTHING. lol
