check the tps. ive done a smog on a old ford dually that would barely fail for CO and after doing the ford self tests it turned out there was a code for tps sensor that was out of adjustment/range
why i faild emissions test ?
Originally posted by wed3k View Postcheck the tps. ive done a smog on a old ford dually that would barely fail for CO and after doing the ford self tests it turned out there was a code for tps sensor that was out of adjustment/rangethis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Swaping it out will do you no good untill you adjust the TPS to factory specs.
02 Crv
Originally posted by SOHC-FTW View PostSwaping it out will do you no good untill you adjust the TPS to factory specs.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Still has to be adjusted to 4.5 @ WOT and .5v at closed. The TPS is not a slap on and go part i'm just giving you a heads up before you waste your time again.
02 Crv
Originally posted by SOHC-FTW View PostStill has to be adjusted to 4.5 @ WOT and .5v at closed. The TPS is not a slap on and go part i'm just giving you a heads up before you waste your time again.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
ok i went and bought a multi meter tired of dicking with this thing . what setting do i set this for ? its way different then what my friend has .
[IMG][/IMG]this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by cloudasc View PostTurning the dizzy towards the firewall retards timing, towards the front bumper is advancing. I would say set your timing (with the service connector jumped) to the middle line, or 15* btdc, which is where it would be when it rolled off the assembly line 20 years ago.
Looking at the distributor on the engine from right side of the car, do you turn the distributor counter clockwise to retard the timing?A&P-IA
Originally posted by oyajicool View PostCan you clarify this statement?
Looking at the distributor on the engine from right side of the car, do you turn the distributor counter clockwise to retard the timing?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Car safety checks
Fluid Capacities
Originally posted by cloudasc View PostOh, just out of curiosity, what ecu are you using? PTx-xxxthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Car safety checks
Fluid Capacities
Your closed throttle is good, but what about at wide open throttle (WOT) it needs to be 4.5V you can do this without the car running just crack the throttle all the way open.
Usually if CT is .5 the WOT will be right at 4.5, but it's always good to check it anyway.
02 Crv
