Originally posted by Accord problems
View Post
why i faild emissions test ?
Originally posted by SOHC-FTW View PostYour closed throttle is good, but what about at wide open throttle (WOT) it needs to be 4.5V you can do this without the car running just crack the throttle all the way open.
Usually if CT is .5 the WOT will be right at 4.5, but it's always good to check it anyway.
i took it for a test drive after letting it worm up for 15 minutes . it seam to have more balls on WOT . but my shifting is now has a little stuble . i think thats just a little cable adjusting . im looking for the diy for cable tranny adjustment .Last edited by Accord problems; 06-28-2012, 04:22 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
this site will be geting anothere five bucks donated from me . this info has helped me fix a lot of things the past couple of days and saved me probly 1k in loans to fix it.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
What letter comes after the PT6? L or A? If its L, its a cali emission ecu, while if its an A its 49 states. It might play a factor in passing smog.
Edited for accuracy.Last edited by cloudasc; 06-28-2012, 09:35 PM.
Originally posted by cloudasc View PostWhat letter comes after the PT6? L or A? If its L, its a cali emission ecu, while if its an A its 49 states. It might play a factor in passing smog.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
And for Oyajcool, its when your looking at the engine from the front bumper. From passenger side, its clockwise to advance, counter clockwise to retard. If your on the drivers side, counter clockwise to advance, clockwise to retard.A&P-IA
Originally posted by Accord problems View Posta ( crap sack) . i got to change that to dont i?
Oyajcool, as for my reference its based off a time when a mechanic said he advanced my timing all the way, which pegged the distributer closest to the bumper. That is what my information is based off. If I am incorrect, I appologize.
Also op, can always tell us which way he turned the distributer to get from 13*btdc, to 15*btdc, as per noted on his smog sheets.Last edited by cloudasc; 06-28-2012, 09:34 PM.
Originally posted by cloudasc View PostYour smog readings are so close to passing, and everything else about your car seems to be working properly, so maybe see if there is another member in your area that has a pt6-l5x, and swap it in for a quick emissions run.
Oyajcool, as for my reference its based off a time when my mechanic (used to work for honda, and was certified during the time our cars were made) advanced my timing all the way, which pegged the distributer closest to the bumper. That is what my information is based off. If I am incorrect, I appologize, but if that were the case I am pretty sure someone else would have corrected me already.
Also op, can always tell us which way he turned the distributer to get from 13*btdc, to 15*tdc, as per noted on his smog sheets.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by wed3k View Postso i still don't have a straight answer about doing valve lash.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Advance is counter clockwise
Retarding is clockwise
02 Crv
Originally posted by SOHC-FTW View PostAdvance is counter clockwise
Retarding is clockwisethis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Accord problems View Postyes i used a loan book from auto zone to set them they are not loud . but they have little sound very little i can still here them.
Originally posted by wed3k View Postdid you set them when the motor is stone cold?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by cloudasc View PostOyajcool, as for my reference its based off a time when a mechanic said he advanced my timing all the way, which pegged the distributer closest to the bumper. That is what my information is based off. If I am incorrect, I appologize.
We didn't need another wrong information circulating around on our forum and that is my thought.A&P-IA
