New spark plugs...which is the best?
    I am about to replace the valve cover, gasket, plugs and wires. I got everything but the new plugs. Wondering if anyone had any reviews of good and bad plugs to get?
    Thanks in advance!
    Ngk
    wat?
      ^^^ because it says so in the manual
      C-3PO's MRT USDM yo!
        NGK or Denso are pretty much the best you can get. You really don't need anything fancy, unless you have some serious mods. The only thing you'll gain from using platinum or iridium plugs will be a longer interval between necessary plug changes.
        Also, when you get wires, the best to get would be Sumitomo... the OEM wires. They're better than just about everything else on the market. A close second would be NGK (their blue wires, if there are any other options.)
          Very wise recommendations
          NGK and Denso are by far the best quality in the industry for spark plugs. Between the two I have always used NGK, with the availability of several heat ranges and the quality of Iridium used.
          For stock application, stick with factory recommend heat range and as deevergote mentioned, you'll gain longer interval between plug changes when using Iridium/Platinum.
            Also, it would be smart to purchase a gapping tool, and learn how to use it properly. Most plugs come pre-gapped, but sometimes they're not gapped as they should be. Plug gap should be inspected when installing, and corrected if need be.
              They're only like 75¢ or something, I haven't had to gap NGK plugs but I always check
                I had to gap a set of iridium plugs that I got. I forget if they were NGK or Denso. I think NGK. 2 of the 4 were slightly off. Probably not enough to matter, but I fixed them anyway.
                  Same, the guy at the store counters always say they come pregapped but for my peace of mind I always check.
                    ive always run NGK plugs in all my cars never had any problems with them going bad on me. i would recomend the NGKs anyday.
                    If at first you don't suceed, then skydiving is not for you.
                    I try not to down talk anyone, when I read my old questions I realize I was an idiot too.
                      Thanks in advance!
                      OEM Honda = Valve cover and valve cover gasket.
                      Spark Plugs and Wires = NGK
                      NGK is OEM recommended, always worked and should always will.
                      V-Power, G-Power or even Iridium is fine from NGK's spark plug line.
                      OEM Honda is fine for the gaskets, I don't see why you would need to replace the full valve cover unless it is damaged though.
                      Current:
                      2007 Acura TL Type-S 6MT KBP
                      Past:
                      1992 Honda Accord EX-R Sedan - RIP
                      1991 Honda Accord EX-R Wagon - RIP 10/14/2010
                      Words change lives. You just got to choose the right ones.
                      Instagram: @CB7Nub
                      Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
                        NGK .. I used bosh platinum when I first got my 6gen accord and it really affected the high end of the power ban switched to NGK and it made a huge difference.
                          I would go with the best ngk has to offer. I think it is worth it.
                          visit vgruk
                            You aren't supposed to gap iridium plugs. Huge potential for damaging the small/delicate electrode.
                              If you are trying to fix the oil on top of plugs issue, then be sure you get the full seal set, the seals under the cam rocker are not fun to get to and it is no fun to repeat your work if the initial fix did't really fix the problem. I had to do this when I first bought my CB7.
