i have a 1990 accord and the tach just quite wat do i check
tach not working
Sensors?
Did you even try the search button?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
i cant post a link for some reason but here .
if you use the search function on this site that is provided you will fiend a thread called . cluster issues.
this was posted bye crazy Mikey.Originally posted by crazymikey View PostOnce you disassemble the cluster, all 4 gauges are separate and can be replaced individually.
Your ICM in the distributor can cause your tach issues. One of my CB's is currently doing what yours is with the tach, so I'll be trying to repair that tomorrow.
What you need to look out for if you're swapping parts from your cluster, is that you will need to find a matching cluster.
There are 2 models of clusters. You will find on the bottom of your speedometer face it will say either ND Nippon Denso, or NS. Components are NOT interchangable between those two. You need to swap NS parts with NS and ND with ND. Also, 90-91 clusters are different from 92-93 clusters, as the pig tails and the wire harness plugs (the 3 main green plugs) are different sizes and do not fit.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
