Im in the process of installing new timing belts finally, and I've looked at the stickies , watched a couple of videos on youtube, and I cant seem to get a good understanding of how to time my rear balancing shaft. I've got an f22a6, on some of the videos i watched the maintenance hole was never even addressed, and there seemed to be timing marks on the pulley itself and the block, but i cant seem to find the mark on my block, assuming there is one. Or is the maintenance hole a must use thing on my motor?
Rear Balancer Shaft
You must use a 6mmx100mm bolt or a screw driver in the balance shaft service port. If you don't you run a larger chance of not being in time with the rotational forces.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
The last t-belt job I did was on my 95 Odyssey, I finally used the maintenance hole to time the rear shaft, it worked out great. It was one less thing to worry about since it spins so easy while putting the belt on. Then you just have to worry about the front bal. shaft and that's about it. You can use a bolt, a drill bit, a screwdriver, as long as it fits in the hole, as tight of a fit as possible will yield the most accurate positioning. At the same time, spin the rear shaft and push in on the bolt and it will slide right in all the way holding the shaft where it needs to be. I'm going to assume you know where it is but just in case, it's the only 12mm bolt w/ an aluminum crush washer on the back of the block, 1/2 way between the t-belt area and oil filter and also just above the axle shaft.
[IMG]
[/IMG]
This is off of my spare engine, F22A1, which was installed on Prelude as I was told. The markings on the casting is not "V" as I first thought as you can see.
Yours does not look the same as mine,,,,,
I thought A1 and A6 share common parts on blocks. And thought the balance shafts are among those parts.
Comparing the photos, you could guesstimate the location of markings by referencing bolts and poke a stick in service port. If it goes in, then, your aft shaft is timed.Last edited by oyajicool; 07-13-2013, 04:46 PM.A&P-IA
I'll figure it out. Thanks for the help amigos! Now that I better understand what I'm doing mechanically I think it'll be much easier.Last edited by Matthyooz11; 07-13-2013, 04:38 PM.
Scrap what I said above.
Pulled the actual shaft off the shelf and I see the timing hole on it.
It is "off centered", so there's only one orientation that a stick would go in. There's no need for aligning markings on the shaft.
Sorry for misinformation.
Good luck with your work.Last edited by oyajicool; 07-13-2013, 04:54 PM.A&P-IA
They are the same, his just has the balance shaft retainer in place.1993 SE Coupe MRT - 1992 LX Sedan MRT
Are you talking about balance shaft seal retainer?
I guess his has a plate that I didn't get on my block for some reason......
Looking at the page of the manual I posted, I can make out that plate in the picture,,,,. I guess some one worked on my spare engine didn't put everything back onto the block.Last edited by oyajicool; 07-13-2013, 05:14 PM.A&P-IA
It's referred to as a side plate...13519-PT0-000... Not sure what engines they came on. Or what function they serve!Last edited by GhostAccord; 07-13-2013, 05:19 PM.
Actually his pulley also has the ridge it is just behind the side plate. Look closely.
Both my '93 F22A6 and '92 F22A1 have the plate. The FSMs I have it is shown in the '92 FSM but not the '91 FSM. So maybe it is a 9293 feature.
