Hi!Pardon me guys if i am posting on the wrong section.......i am new here and i still a little lost so flaming suit is on.I am the proud owner of a 1992 honda accord lx coupe.Motor and transmission is all stock....well it has header,msd external coil,msd box,msd wires,adjustable fpr,lowered,rims....the basic amateur upgrades but it feels slow,incredible slow.I come from building rotaries and my other ride is a 600hp monster,i am used 2 power lots of power so i am thinking wondering about turboing the accord with some leftover parts.I can build,weld,modified my own parts but i need help choosing what 2 use.In the rotary world you run huge AR turbos with cold sides from 67mm and up on a daily driven rotary in order 2 make power but so far i read that this turbos are 2 big for the 4 bangers.Engine managment is another thing,i seen so far that you can upgrade factory honda ecus and they will act,run like a standalone unit,how truth is that?So far i have the following parts set aside for the build.
60-1 big shaft ball bearing turbo with a 1.0 divided 3 inch vclamp outlet.
Manifold still in the making,trying 2 decided if turbo should be mounted on top or on the bottom.
40mm hks wastegate.
4 1000cc low z injectors.
custom fuel rail.
tial 50mm blv
ebay front mount
feed and drain lines for turbo
new act clutch
flywheel
lsd
and some other stuff.
So what EMS do you guys like,use or is highly recommended.I have a LT8S with Xbox from another rx7 that i can get reflash and run in the accord,anybody runs MICROTECH in here.
Well that is for now but i do have a bunch off other questions.
40mm hks wastegate.
custom fuel rail.
tial 50mm blv
ebay front mount
new act clutch
flywheel
lsd
