oil mist in the air intake pipe?
    I was replacing the air filter and when I checked the pipe that goes from the air filter to the intake I noticed there is an oil mist in the pipe. I could clean it but it doesn;t look well . Where is that oil coming from?
    The filter was clean as long as oil goes.
    help!
    PCV most likely venting off the mist into the plenum.
      Well, I had the PCV broken once. It gave me the code and everything ( CEL). I have to admit I drove the car with a busted PCV for a short period of time (weeks). Meanwhile I cleaned the PCV ports and replace the PCV....all these was 6 years ago.
      I am going to check the PCV and give a clean in anyways.
      Thanks for the hint
        Are you sure that you are talking about the same system? The PCV, is the positive crankcase ventilation system. Sounds more like you are referring to the EGR, Exhaust gas recirculation system. The PCV doesn't have any ports, EGR does and there is no CEL for the PCV.
        The PCV is the tube that goes from your valve cover to your intake manifold. When this valve gets plugged the dirty oil filled air will back up and go through tube going between the valve cover and the intake tube. I think this is probably what is going on if you still have this system intact.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          You sir, are 100 &#37; right! I got all confused.
          Going to check the PCV tomorrow..I do have that valve on .
          I was about to take apart the EGR valve and give a clean, thinking it was the PCV, but decided to do it tomorrow....hahahhaha
          Thanks man!
          PS: What did you mean by the "system intact" ?
          PS1: How do i know it is working properly? Should I give a clean ? or replace it?
            System intact - Meaning the OEM PCV complete with the PCV valve on the valve cover going to the intake manifold and the fresh air intake hose going from the intake tube (before the throttle body) to the valve cover. A lot of times guys will delete on of these thinking that it will help with performance..... Just wanted to see if you still have the OEM system installed!
            A lot of times you can remove the PCV valve and give it a cleaning with a can of throttle body cleaner, or soak it in warm soapy water for a few hours, while giving it a good shake from time to time.
            Another problem is that sometimes the PCV hoses will become clogged or collapse in on themselves, this will cause a restriction and possibly cause the dirty air out the clean air hose going to the intake tube.
            MR Thread
              then, the system is intact.
              I will check it out tomorrow. I guess if it is there, it is for a reason. I will check the valve and the hose.
              Cheers,
                update:
                I was prying off the PCV valve and the grommet was brittle and broke off. Thanks god , the pieces were visible and I could take them out of the engine cavity....
                The PCV valve looks like working but the sucking is not that strong.
                Should I go and buy the pcv valve and the grommet all together or just the grommet?
                How can I know if the PCV is working properly.It should suck in when engine on idle, but how strong should the suction be?
                  It should be strong enough that there is suction from the hose on the other end of hte valve cover.
                  if this doesn't fix the issue it is probably due to excessive blowby in the engine at higher RPMs. Not much you can do with this other than to instal oil catch cans on the hoses.
                  MR Thread
                    I see. The PCV looks fine , the valve looks fine. It is one way. Towards the intake manifold the is flow. And it closes the other way. Although if one blows hard enough, there is air coming out of the end going into the engine. Is that a good PCV?
                    An oil catch can...who would have known. It is not that serious. I noticed it by accident I saw the pipe looking shinny and it was like an oil spray had been applied, not runny , just a mist.
                    I barely reach 3000 at the rpm, when I drive it. This must have been when I took it to new brunswick, lots of steep hills up there.
                    Thanks for the hints man!
