-93 Honda accord ex.
Let me start with the basics.....
I have a slight antifreeze leak. I've been keeping coolant in it. About 3 weeks ago, I noticed my car was getting super hot. I pulled over and let it cool down, then drove it home. At this point in time, I'm almost positive its not a water pump issue. (i'm hoping someone can clarify this for me.) When I turn the heater on full blast (defrost) the car wont overheat. I can drive it all around town, on the freeway, everything. (I live in Utah, its winter right now.) That lets me know that antifreeze is pumping through the second "radiator" that is used to heat the cabin of the car. That being said, my next step was to check the fans. I had noticed I couldn't hear them coming on. So I got my car fairly hot, popped the hood, and checked to see if the fans were on. they weren't. So I figured that was the culprit. First thing I did, I hardwired the fans strait to the battery. They work. Then, I shorted out the pig tail clip and that turned them on. So at that point, I replaced the coolant temp sensor. (the one that's NOT next to the thermostat. It's on the top coolant hose, I believe.) Now the fan comes on when I turn the car off. ( I know the fan is supposed to do that when it gets hot.) but now I cant figure out what I need to do to get them to come on when the car is on... when it actually matters lol. I found the second coolant temp sensor that's next to the thermostat at a junk yard and i'm going to put that in today to see if that might be the problem. Please, anyone with more knowledge about this, let me know. I care very much about my car and it drives me insane when things don't work properly. and i'm definitely not going to pay someone my entire bank roll to fix it.
Thanks, -koda259
Thanks, -koda259
