I have a 1992 honda accord ex 5 speed with 4 wheel abs. The abs light comes on after engine is started and i start to move. I start the engine and everything checks ok. Once i start to move either in gear or neutral i hear a whistle sound like a pump has activated. This lasts for about 6 seconds and as soon as it stops the abs light on dash comes on and stays on until i turn off engine. Thanks in advance for any help.
abs light comes on after moving
Typical problem is a bad wheel sensor. Do you know how to jump the diagnostic connector (blue with two wires/sockets) under the dash to the right of the glove box? Use a piece of wire or paper clip to jump the connector, then turn the key to the "on" (do not start the engine) position, then count the flashes to get any code/codes.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
The code i got is wierd. Am guessing it is 1-0. I got 1 blink then a 6 second pause then 1 blink again and another 6 second pause and 1 last blink. All the blinks were of the same length and nature. The blink seems to be a long blink. So do all codes repeat itself 3 times. Is that what is happening here. It just repeated the code 1-0 3 times.
These should be the codes here, assuming they are correct (I've never owned a CB with ABS, so I have no direct personal experience.)
http://www.cb7tuner.com/vbb/showpost...28&postcount=2
Originally posted by ExplodingCake1 Hydraulic pump motor over-run
1-2 Hydraulic pump motor
1-3 High pressure leak (possibly modulator)
1-4 Pressure switch
1-8 Pressure accumulator
2-1 Handbrake warning lamp switch circuit faulty
3-1 Right hand front rotor damage
3-2 Left hand front rotor damage
3-4 Right hand rear rotor damage
3-8 Left hand rear rotor damage
3-12 Different tyre sizes fitted
4-1 Right hand front wheel sensor
4-2 Left hand front wheel sensor
4-4 Right hand rear wheel sensor
4-8 Left hand rear wheel sensor
5-4 Right hand rear wheel lock
5-8 Left hand rear wheel lock
6-1 Front fail safe relay
6-4 Rear fail safe relay
7-1 Right hand front modulator solenoid valve
7-2 Left hand front modulator solenoid valve
8-1 ABS operation fault
8-2 Electronic control unit (ECU) fault
8-4 Electronic control unit (ECU) - internal circuit fault
It seems that your code may be the very first one, which seems to me would indicate a bad ABS pump.
Make sure your fluid is full and clean. That can cause problems with the system.
