`Hey All,
So recently I been having a problem with my cars accelerations where the RPM would drop or spike all around.
Here is a video of what exactly is happening.
*https://youtu.be/qwXtBw8hmMw
So before hand it was running fine and no fluctuation or spiking of any type. So as far as I know I had only just changed the distributor because the old one was leaking due to a old o ring seal. So after that it started up fine and actually had a more kick to it, when I would first start off. But as I would go through the the 3 to 4 automatic gears it would spike and or drop on me and just struggle.
Right now I am struggling to understand if it is because of the new distributor replacement? or the timing or grounds are messed up or the VSS (Veichle Speed Sensor) or even a leaking of air..
Please let me know what you think and any experiences that have happened to you!
P.S
I have tried my best to research but it was something diffrent from my situation where others have had only 100 rpm jumps or small spikes but for me it is a big spike from 1500 rpm to 5000 rpm or from 3000 rpm to 1000 rpm!
P.S
