The problem: the brakelights are on constantly even if the car is off.
What I've done: a search for this issue on the message board and found good info and have tried several things i read. I have replace all the bulbs, i replaced a pigtail which i thought was the issue...i've cleaned any dirty connections..made sure brake fluid is topped off...checked all fuses...
What i found: i found the little circuit board on the passenger side tail light and it was damp...i cleaned and dried it all up...the only light that doesn't come on is the third brakelight and the bulb has been replaced....
would i be correct in replacing the small once wet circuit board at this point or should i try some other things out prior to that? has anyone had the same issue before and was able to fix it?
Any help would be greatly appreciated...
