which engine is better for boost???
    which is a better candidate for boost???
    a stock f22b???
    or...
    a stock h23???
    A wise man sees failure as progress...
    they're basically the same motor but 9 times out of 10, the f22b will have significantly less mileage and be in better shape than the 2.3.
      righ right...u know anybody with a boosted f22b setup...?
        Actually they are not the same motor well kinda. Blockwise they arent and the h23 has more stroke if I remember correctly. F22B will be able to handle boost because of the similarities it shares with the F22A block. bjaccord did really well with his h23 setup pushing around 280 or so whp and coulda been higher. In the end both can make power it depends on tuning mostly.
          the h23 hands down, stronger block, but like karl said before alot of miles though
            i agree f22b alot less miles but the h23 is proven already so its ur choice... i personally would choose the f22b. Im actually soon gonna get a f22b dohc swap because its practically new
            1990 Accord EX Sold
            1995 Accord LX V6 Stored
            1999 Accord LX Daily Driver
              so does anybody have a boosted F22B setup or a boosted H23 setup...cuz i just wanna see numbers...hp...torque...
                I have a boosted h23 and i love it. if you are going to be buying a new engine you can get the jdm h23's and they are low milage. its up to you the f22b is usually a little cheaper to buy too. I know the place here in town that sales motors only wants 650 w/o tranny for the f22b.
                  what makes the h23 so much greater over the f22b? If anything it would be the displacement, strokes the same as the f22s, since the crank/rods are the same, it's the piston/bore that gives the displacement difference. h23 have frm sleeves, so that makes it a hassle to upgrade. h23 has higher compression then the f22b, meaning less room for error, and I maintain the f22b head is better then the h23(no fact there, pure speculation). IMO, the f22b would be better for boost.
                  Shift_BOOST
                  BOOM!
                    i actually have a jdm boosted f22b. i am hoping to get tuned this saturday, so when i get the info, i will share it with the forum.
                      Lets pull your head this weekend and compare I'm down for it if you are, I'd like to know as well.
                      As weve kind of discussed before, they make very similar power from the factory, with the f22b looking to be the weaker motor on paper (Displacment and compression) but no one really knows why.
                      If I were going to boost another factory motor, I really wouldn't care which motor I boosted, I'd just buy which ever was cheaper and lower mileage.
                      Turbo H23a3 build has begun
                      01-01-2019
                        Don't all F22's have iron sleeves from the factory? If thats the case you could run a forged piston no problem.
                        To me that would be a much better block for boost over the H23, I don't think a 100 cc's is gonna matter if you're boosting.
                        www.roskoracing.com << Euro-R manifolds/adapters and H22 parts
                        >>check out my H23vtec build thread...
                        http://www.honda-tech.com/zerothread?id=2030543
                          f22b has less torque as well
                          Yeah, Preludes
                          Why can't people just search OT to see if someone else posted the same random thread?
                            Doesn't matter when boost is involved... Rosko, you're right about the sleeves. You can run forged pistons with the F22B. The H23 will need special pistons (not even sure if they're availible). Of course, that's with the stock sleeves. When you reach a certain level of boost, you'll need to resleeve either motor anyway.
                            Stock for stock, just get the one with lower mileage. They're both plenty strong to handle lower boost levels in stock form... just be sure it's healthy, and tune it properly.
                            IMO, I'd rather boost the F22A. The head flows well, the block is strong, it's cheap as dirt, and DOHC ain't all that I've seen boosted F22As run mid-11s... and then drive home. Don't discount the stocker!
                              Mahle makes an FRM compatable forged piston, its the "Mahle Gold Series" specifically. Its a different alloy from your standard forged piston and its also coated. The downside is that the particular alloy is a bit heavier. Mahle is a well known piston manufacturer, but as for these pistons I've heard mixed results and if it were me I wouldn't bother. *shrugs*
