So. I need some help.
For the past month I have had the dmm iny car monitoring the voltage. It will consistently go from 14.4 down to 12.4. Usually when I let off on the gas. Not all the time but that is the trigger. Sometimes it goes back up usually it doesn't . Once I use a fairly heavy acc (ac rear defrost)the voltage comes back up.
I have always had to replace the batt in this car every two years not matter what batt I put in.
Well Monday it 35 outside car wouldn't start. Took battery to autozone. It's dead. The batt was a 24 series, not sure why they gave me that one, anyway I replaced it with 34 series, more cca.
So after the batt died I took my old alt to advance. They tested it. Said it was fine. So I put it back on. Took the high output one up to be tested it failed.
So after that I thought that must be the problem. Nope it is still there.
Connections are good and tight grease on them. Belt is tight. Batt is new and alt tested out good.
What am I missing? Is this normal? Ie if the car doesn't need power does it regulate it Down to 12v. The odd thing is when driving the voltage goes down to 12.3. With the car off the voltage is 12.6.
This is baffling me.
As always thanks
Steve
As always thanks
Steve
