OEM Foglight Switch Diagram
    can an aftermarket harness from autozone for example work to power the fogs. i am planning on using the oem switch?
    Originally posted by visualpoet
    some owners think it's the best thing since titties
      yes, if u wire them to the oem switch of course. any harness will work with the oem switch as long as u wire it correctly.
      (129)Transactions and counting
        no no i mean like what other plugs in our car will plug right into the OEM plug. (ex. the plug for hazzard switch could plug into the fog switch but needs to be re wired of course.)
        Members Ride sold...
            thanks
              okay the brake light plug that goes to the outer light plugs into the foglight switch... just found this out.
                You will need to mod it (add the 12v wire which is blank on the brake molex), but yes it does plug into the oem fog switch....
                Tom
                92 Accord LX
                My Ride
                  Tom
                  not a prob just repin the wire
                    You could also get the molex from the pass side rear tail light of a mid 90's prelude or either side of a acura vigor. These are plug and play, no need to mod. I am sure there are other cars with this molex also, but these are the ones that I have seen in person....
                    Tom
                    92 Accord LX
                    My Ride
                      hey scott do you know which wires which on the defrost? i'm trying to splice into them to power my fog switch but dk which wire to tap into.
                      x2
                        Originally posted by DejectedAngel View Post
                        My switch is exactly like the one pictures. Which is the diagram for the wires or is the first post the right one?
                        Can anybody give me the exact diagram of this switch above?
                          this diagram is 100% accurate for ALL OEM CB FOGLIGHT SWITCHES:
                          http://www.cb7tuner.com/vbb/showpost...15&postcount=5
                          the red and red/black wires, it doesnt matter which is which. this step is strictly for illumination, so youre just piggybacking off the wiring that leads to the defrost button.
                            So the Black Wire A is actually +12v not ground?
                              yes (pins A and D are reversible). it will work perfectly if you wire it up as indicated.
                                so A,B, and D are in the same location on the defroster as they are in the fog light switch right?
